Hi Campers,
         Is there any reason anyone can think of why a Honda EU2000i generator would not show up on the Xantrex freedom x device in my Oliver Elite II?
Is it not powerful enough?  Or is either the generator or the Xantrex freedom x not working properly.  Of course, it could just be me!
I started up the generator.  Waited until the green light on the generator indicated it was producing enough voltage.  Then I plugged the cord into the generator first, and then the Oliver.
Is it me, or is it something else?
       Would appreciate any advice.
Charlie
Citrus Breeze
Charlie
Hull 734 - 2021 Oliver Elite II
pulled by F-150
Out of Florida
Hull 806 here....
I have the same model generator....are you using a neutral bonding plug? This is a must have. You can buy them...I made one via youtube and it works fine.
Thanks, Steve
I was just researching on the old internet, and read about the necessity of a neutral bonding plug.  I hope to find one near where we are camping tomorrow.
Hull 734
Charlie
Citrusbreeze
Charlie
pulled by F-150
Out of Florida
5 minutes ago, Citrus breeze said:
Thanks, Steve
Hull 734
Charlie
Citrusbreeze
Camping world. Rv center. Amazon.
Also if you have the Xantrex Freedom X 3000 you might experience your Honda 2000 getting overloaded. This happened to me. You can change  the Xantrex Settings to lower the draw and eliminate the overload.
To do this:
Turn on your inverter
Hold the bottom button for 3 seconds until the readout changes to [00] 1
Press the middle button (^) to toggle through the settings until you get to [28] 25A
Press OK until  25A is blinking then press the middle button (^) to toggle through to change the setting to 15A. You will have to go all the up to I think 50A to get back to the lower numbers. This will lower the draw to keep the generator from getting overloaded. When you are back to a 30A power supply you should change this setting back to 25A so your batteries will charge fast.
2019 Elite II Hull 435, 2022 Toyota Tundra
You can press and hold the ^ button to go backwards (down) through the settings.
