RustyMD Posted January 5 Share Posted January 5 Weather stripping on street side front window is coming loose. What’s the fix? Robert Youens 2023 LEII Hull#1304 Robert Youens 2023 LEII Hull #1304 TV 2022 RAM 1500 5.7L Hemi e-torque with tow package Link to comment Share on other sites More sharing options...
SteveCr Posted January 5 Share Posted January 5 Hello, That looks like the removable weather striping. You just push and seat it back in place. You remove it when you clean the window track and weep holes. Steve 1 3 Link to comment Share on other sites More sharing options...
Frank C Posted January 5 Share Posted January 5 It’s removable for cleaning the window tracks and weep holes. It’s easily pushed back into place. 1 2 2019 Oliver Legacy Elite II - Hull #461 Tow Vehicle: 2019 Ford F-250 SuperCab 4x4, 6.2L Flex-Fuel engine Link to comment Share on other sites More sharing options...
RustyMD Posted January 5 Author Share Posted January 5 I pushed it back a few times and it fell out again. If it were a millimeter wider it would be perfect. Robert Youens 2023 LEII Hull #1304 TV 2022 RAM 1500 5.7L Hemi e-torque with tow package Link to comment Share on other sites More sharing options...
Frank C Posted January 5 Share Posted January 5 14 minutes ago, RustyMD said: I pushed it back a few times and it fell out again. If it were a millimeter wider it would be perfect. That’s odd. Might be either a defective piece of weatherstripping or the window frame may be deformed a bit too wide. I’d try swapping that piece of weatherstripping with the piece from another window to see if the problem follows the weatherstripping or the window. 4 2019 Oliver Legacy Elite II - Hull #461 Tow Vehicle: 2019 Ford F-250 SuperCab 4x4, 6.2L Flex-Fuel engine Link to comment Share on other sites More sharing options...
RustyMD Posted January 5 Author Share Posted January 5 Thanks for the responses. I’ll likely take it out and try various arrangements. Robert Youens 2023 LEII Hull #1304 TV 2022 RAM 1500 5.7L Hemi e-torque with tow package Link to comment Share on other sites More sharing options...
Moderators Mike and Carol Posted January 5 Moderators Share Posted January 5 I remove ours 2 or 3 times a year for cleaning. No issues with it staying in place. I wonder if your window might have a gap that’s too big. Mike 2 Texas Hill Country | Elite II #135 | Ram 2500 6.7L Link to comment Share on other sites More sharing options...
bhncb Posted January 5 Share Posted January 5 1 hour ago, Mike and Carol said: I wonder if your window might have a gap that’s too big. Mike Mike might be onto something here. Take a real close look at the joint I've circled in the picture. The vertical separator piece is notched to provide relief for the frame. It looks like this joint may not be put together correctly and the separator is pushing the frame channel apart. If so, open a service ticket and include a close up shot of this area. 4 Link to comment Share on other sites More sharing options...
