My experience with lithium and fire is relatively small - a laptop battery pack.
However, I can tell you that it can get exciting!
As those individual cells that are on the inside of the battery come shooting out of the case, bounce off the ceiling of my office and then melt into the carpet while setting it on fire and other cells have already turned paper, a trash can, a lamp shade and a desk on fire, I knew that I had to pull the plug out of the outlet in the wall in order to stop the current from igniting even more cells.
Once the power was removed from the equation then a Tundra aerosol spray fire extinguisher ( like THIS ONE) quickly took care of the fires.
Given what I believe would be somewhat larger individual cells in our Ollies I believe that you simply can not afford to be too safe.
Agreed.  But, one reason I understand Oliver chose Lithionics for its LiFEPO4 batteries is the built-in Battery Management System, which includes "shut down curtain technology" designed to prevent thermal runaway.
The Lithionics website says it this way:
"Lithionics Battery® uses an organic Lithium-ion Iron Phosphate chemistry in all of our lithium battery models. This naturally safe chemistry is paired with an internal shut down curtain technology inside each lithium cell, preventing any flame or explosion from thermal runaway events."
I once had a lithium-ion cell phone battery heat up and expand to more than double its original size.  That scared me.
LiFEPO4 is one kind of lithium-ion battery, but "ordinary" lithium-ion batteries (like those used in cell phones and laptops) are not LiFEPO4.  LiFEPO4 chemistry is much safer, and is not prone to explode, like a laptop battery can.
I sleep better at night knowing that the much larger Lithionics batteries in my Elite II are not only LiFEPO4, but have the shut down curtain technology built in.
Very true!
The Battleborns also have internal management for overcurrent and temperature.  And also are the same chemistry as the Lithionics.   As such, I don't worry about our batteries running away to thermal overload.  What I do keep in mind is the remote possibility of something drawing less than 300 amps when it should not be, and having a way to shut that down too.  For fire.... belt and suspenders.  @ $40 bucks and some DYI time.....no brainer....
PS:  Additional benefit is having a simple way to isolate every DC parasitic current draw with a flip of a switch.  As a sage owner reminded me some time ago when I said I just took off a terminal wire... His response was something like "Every weekend???"  Slam dunk great response.     I know at least one of you is out there smiling now.   🙂
