GraniteStaters Posted March 9, 2023 Posted March 9, 2023 (edited) I wanted to run my furnace to heat the trailer without using any of my onboard propane. I have this valve setup for quick connect for my propane generator so I simply borrowed it for my proof of concept. Worked like a charm as I thought it would. Edited March 9, 2023 by GraniteStaters Formatting issue 10 David Caswell and Paula Saltmarsh Hull 509 "The Swallow"
GraniteStaters Posted March 9, 2023 Author Posted March 9, 2023 I said valve, but I should have said regulator. 1 David Caswell and Paula Saltmarsh Hull 509 "The Swallow"
Mainiac Posted March 10, 2023 Posted March 10, 2023 Good idea. But, would that fill a 20 lb from the onboard 30s?
GraniteStaters Posted March 10, 2023 Author Posted March 10, 2023 I don’t believe so, but I had the 30# tanks shut off while I did this. 1 David Caswell and Paula Saltmarsh Hull 509 "The Swallow"
Geronimo John Posted March 19, 2023 Posted March 19, 2023 With the on board tanks shut off, if an Owner fount themselves in a frosty environment for the winter..... I shutter to even contemplate such an event with my Hawaii thin chicken skiin, ... they could call a local propane company to deliver a real tank and your idea would be really handy. Hawaii/Safety/Geronimo John 🙂 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
