2021 Legacy II Hull #728 Pulled by 2015 Toyota Tundra 5.7 with 6.6 bed with Decked pullout.
300 Watt Bouge cigs flat solar. dual 30# propane tanks w/GasStop safety devices and Mopeka tank sensors, Victron Multiplus II 12volt., 400 x Battleborn Batteries ,Victron SmartShunt, Victron cerbo and screen. 2 x Victron Smart solar 100/30 and 1 x Smart solar 100 x 15. 800 watts ground panels. Mopeka tank sensors x 2 , Tempature sensors fridge battery compartment Ruuvi tags with fans. 12 volt  Nova Kool refrigerator. Tosot A/C.  Pecron E3600 + 2000 and 2000 Batteries with victron Orion 50amp dc to dc charger.Electric water valves and IRVWPC2 water pump controller. Truma on demand water heater. Added outdoor side Table. Bumper Toolbox, and Many more mods thank you contributors!
When I added one in 2017, it was also too strong.  I moved the magnet from the outside of the dinette seat to inside and it works perfect, plus you can’t see anything on the side of the seat, just the white magnet on the bottom of the door.
RV Door Magnet on Amazon
Mike
10 hours ago, Steph and Dud B said:
The bathroom door flexed too much when releasing, so I added a clear silicone bumper to one of them for a bit of separation.
Same issue we had @Steph and Dud B!  We did the same thing as @Mike and Carol, and placed one piece inside the forward dinette seat compartment giving more separation and less door flex - works great and doesn't have a visible magnet showing when stepping thru the main hatch when the bathroom door is secured.
  • 2022 TUNDRA
