Mike Griffin Posted September 18, 2023 Share Posted September 18, 2023 2023 Elite II with Truma A/C, Truma on-demand hot water heater and Furnace, Isotherm frig. Setting uo at campsite once shorepower was connected the Truma Control Panel showed Alert diamond in center at bottom control panel. When selected the code read W255 W. The manuals provided on flashdrive to not list this error code. A/C would not come on when selected. Anyone have full listing of error codes. I think it is associated with power rocker switch behind exterior access panel for on-demand water heater which we were instructed to turn OFF when preparing to leave for next camping location. Mike Griffin 1 1 Link to comment Share on other sites More sharing options...
dewdev Posted September 18, 2023 Share Posted September 18, 2023 Welcome to the Forum. If your question is not answered here, you might be best off to contact Oliver Service. 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension Maine Link to comment Share on other sites More sharing options...
Tom and Doreen Posted September 18, 2023 Share Posted September 18, 2023 Make sure your Truma water heater main switch is set to the 'on' position. This switch is located on the water heater itself and can be set to either the up or down position. The center position is off. 5 Tom & Doreen • 2023 Elite ll • Hull #1321 • 2023 Tundra Platinum Crew Max • Cheshire CT Link to comment Share on other sites More sharing options...
Ollie-Haus Posted September 18, 2023 Share Posted September 18, 2023 Welcome to the Oliver family and the forum! Steep learning curve those first few days using the Ollie. Just tested mine with the unit switch off and that is the code that popped up on the control panel when I tried to turn the water heater on inside. Not sure why they are saying to turn off the unit switch for travel. I would personally only turn this off for storage. 4 What's today?............. the most frequently asked question as a retiree 🙄 Chris and Stacie Neuhaus Greenfield, Indiana 2021 Ford F350 7.3L Tremor (Redzilla) LE2 #1373 - Ordered 10/21/22 - Delivered 05/10/23 Link to comment Share on other sites More sharing options...
Tom Pilgrim Posted April 30 Share Posted April 30 Just took our factory delivery (a Great Experience…) & stayed at the Oliver campground to spend a night. The following morning, the CP-Panel had the triangle/! icon lite & the water heater icon/information was missing as well. The error code W255 W was displayed when scrolling/selecting the triangle / Icon… An initializing of ‘reset’ resulted in No change…still no water heater info on display. The only ‘problem’ was the 3-position on/off/on switch on the water heater was in the ‘off’ position, so selecting ‘ON’ & then repeating the reset/initializing process restored the water info on the panel - ‘Problem Solved’ 1 1 Link to comment Share on other sites More sharing options...
