Hi all math whizzes.  I took the tv and trailer through twice.  First time with the Anderson hooked up.  Second time without and third time with the tv only.  Does anyone know if doing those three weighs will give me the hitch weight and the trailer weight.  Here are the numbers:
1st weigh-  steer axle 3120, drive axle 4260, trailer axle 5840. Gross weight 13220
2nd weigh-  steer axle 3080, drive axle 4340, trailer axle 5800, gross weight 13220
3rd weigh-  steer axle 3380, drive axle 3400, gross weight 6780
The tv is a 2017 Ford Expedition.  Missing from the tv was my wife at 140 pounds and maybe 100 pounds of cooler and drinking water.  The fuel tank was full as well as the fresh water tank.  Black and gray were empty.  Thanks for any help.  Have a great week all.
John, did you punch those numbers into the spread sheet I emailed you? If yes it will show the hitch/tongue and trailer weight.
**Sold😞**
I will do that.  I have been busy with two grandsons under the age of two.  Diaper changes, bottles, cleaning up, etc.
I could be wrong with my calculations, but it looks like your TV weight went up 600-620 pounds when hooked up which makes your tongue weight (600-620).
Interestingly, the anderson shifts about 40 pounds from the rear TV axle to the front TV axle and shifts 20 pounds from the rear axle of the TV to the trailer axles (I thought it would be more than that), but...there you have it.
Trailer weighed in at 6440 pounds
Albert & Terri Sterns
Paonia, Colorado
Albert, thanks for the math.  We have been in Denver for six days helping our daughter care for her two sons, 2 months old and 19 months old while her husband was in Italy for work.  Lots of work taking care of those little guys.  He's back now and we're heading to Hohenwald by the 29th.  Thanks again.
That can be tweaked by tightening the chains. On my setup 200lb is moved from the drive axle to the steer axle and 140lb from the drive axle/tongue weight to trailer axles.
**Sold😞**
Excellent point - great way to tweak the load fore/aft depending on your load-out for a particular trip.  We target roughly 6 threads behind each of the Anderson chain adjustment nuts. We start there then tweak as needed.  To get a good idea of actual tongue weight we use one of these - real easy to get a quick data point; especially if you're configured differently than the previous trip (tank levels, bikes, etc.).
  • (SOLD) 2022 TUNDRA
I usually have it at 7 or 8 threads
**Sold😞**
This past Summer while visiting at Max Burner's lovely home, Art asked what I thought my tongue weight was.  I guessed 600+ pounds.  He whipped out his tongue gauge.  I was pleasantly surprised that our Ollie's tongue weight was just 540 pounds.  Really good info to know.  Excellent tool to bring to any Ollie gathering!
