Jason Foster Posted November 29, 2023 Share Posted November 29, 2023 12 hours ago, Ronbrink said: We left Palmetto SP yesterday afternoon to have a late lunch in San Antonio, and upon return a few hours later the touch light above the sink was fading in and out. Strange, because no lights were left On. This is one of the lights previously mentioned with a prior problem, but this was a first for this anomaly. When I touched the light it went full bright, but would not turn Off! Sadly, I had to find a way to block the light since I’m a light sleeper, no pun intended! Enter a dinette seat back cushion; to no surprise, another reason for my wife to call me a ‘nut’. So to bed I went, bedcovers over my head, but awakened around 2am with a thought; the Master Light switch. In careful execution and much anxiety, flip Off, light Off; now what? So, with much curiosity, flip On, light still Off, yahoo! As not to push my luck, I returned to bed with a sense of accomplishment and drifted off to sleep once again. However upon awakening, more anxiety and curiosity; will the light come On when touched and operate normally? A resounding YES! Ronbrinks light the next morning. 5 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460 Link to comment Share on other sites More sharing options...
Ronbrink Posted November 29, 2023 Share Posted November 29, 2023 8 hours ago, srthomsen said: Stretch the spring or? No, I just twist off the cover, wipe to remove any dust inside, tickle the spring a bit and reinstall the cover. Thinking either the dust interferes with the action of the spring or the spring is a little out of kilter due to ‘tapping’ the fixture as opposed to ‘lightly touching’ with the back of hand. That said, guilty as charged; if these lights don’t laminate when first touched, I invariably tap, sometimes more than once, until they come on. My bad! Just know, I am now 4 of 4 in remedying inherent issue with these lights. 2 2020 OLEll, Twin, 579 2012 Silverado 1500 4x4 No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt Link to comment Share on other sites More sharing options...
Ronbrink Posted November 29, 2023 Share Posted November 29, 2023 6 hours ago, Jason Foster said: Ronbrinks light the next morning. Now there’s an idea! Would be great in getting my ‘late sleeper’ wife up to make this ‘early riser’ his morning coffee. 3 1 2020 OLEll, Twin, 579 2012 Silverado 1500 4x4 No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt Link to comment Share on other sites More sharing options...
MobileJoy Posted May 1 Share Posted May 1 On 11/21/2023 at 4:28 PM, John Dorrer said: There are a number of owners that have replaced their failed touch lights with something similar that also has a blue night light. I going to buy a 4-pack and have Oliver replace the 2 bad ones. No negative reports on these. Last week I had Oliver replace all of the touch lights with these Obeaming lights. I had three touch light failures, and it might have been more except that we hardly use the ones over the beds. Contrary to others reports, the touch aspect never worked well. The failures were fluctuating light, total failure, and the ability to turn off without using the master switch. They used screws to attach the new lights, and not the screws that came with the lights. Once installed, we found that two of them did not work. They were on when the trailer was returned to us, and my wife could not shut them off. After investigation, it turned out that the lights that had appeared to fail, there was nothing wrong with the electronics. I removed the covers and operated the switches directly. No problem. The issue was that the cover switch button was not reaching the light switch. This was because some of the screw holes were not perpendicular to the mount surface, and so screwing in the light was deforming it (it was not flush to the fiberglass surface all the way around). I removed the screws on one of the lights and elongated the hole in the light fixture so the crooked screw's threads would not catch on it. After reassembly and remounting of the cover, the light works perfectly. I also bought spares since I expect these to be phased out (just as are most things). For easy reference: https://www.amazon.com/dp/B093G795G2?ref=ppx_yo2ov_dt_b_product_details&th=1 3 2 2021 Elite II Twin #850 "Mojo", 2020 F250 Lariat 7.3L FX4 3.55 Link to comment Share on other sites More sharing options...
