Liana Posted December 8, 2023 Author Posted December 8, 2023 13 hours ago, Geronimo John said: Likely the sizzling was water hitting the very hot evaporator section of the ammonia unit IDK, there was also smoke and that distinctive smell of burning electrical insulation. Should the ammonia unit be hot if the fridge isn't operating? Yes there was DC power in that area, but the fridge was off, I would think the ammonia unit wouldn't be hot? But, yes, I'm glad to be getting it checked out. 2018 LE2 #333 "the Otter" 2015 Silverado 2500HD
Moderators SeaDawg Posted December 8, 2023 Moderators Posted December 8, 2023 11 hours ago, JKAY2023 said: I went back and re-read this whole thread again but I'm missing where she said anything about washing her trailer with a pressure washer. Was something deleted before I read this thread? That was my assumption, as I have never had an issue with water getting into the vent while washing with a bucket and soft brush. We rarely use a spray nozzle on the hose, at least not around vents. Sorry for the misunderstanding, Liana. Please keep us posted on what you find. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Moderators topgun2 Posted December 8, 2023 Moderators Posted December 8, 2023 (edited) On 12/8/2023 at 12:11 PM, Liana said: khere was also smoke and that distinctive smell of burning electrical insulation. Should the ammonia unit be hot if the fridge isn't operating? Yes there was DC power in that area, but the fridge was off, I would think the ammonia unit wouldn't be hot? But, yes, I'm glad to be getting it checked out. Well - the smoke and the smell are a good indication that the ammonia "unit" had nothing to do with the issue at hand. Yes, the ammonia "unit" could still be hot even with the fridge off, but, it shouldn't be hot too long after the fridge is off. Certainly, after an hour or so, I wouldn't think that it would be so hot as to cause the sizzling you heard. Yes, as you have already decided, in cases like this it is always better to get things checked out. Otherwise, you will pay the price of constantly worrying that the problem will reoccur or worse. Bill Edited December 9, 2023 by topgun2 spelling 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Geronimo John Posted December 10, 2023 Posted December 10, 2023 On 12/8/2023 at 3:25 AM, gbergh said: If you want to continue to contribute to the forum with comments or to answer questions, please do it without your usual negativity toward Oliver. This time, I'm not asking. Steve :Sometimes a PM is a better choice for communication. Especially when as a moderator you are communicating in a somewhat threatening tone. 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Geronimo John Posted December 10, 2023 Posted December 10, 2023 On 12/8/2023 at 3:28 AM, topgun2 said: Certainly this is a possibility, but, when it was said that the fridge was turned off and then retried a bit later and the sizzling was still heard, I assumed that any water in the area you mention would have been evaporated the first time. Most likely as you stated. But, maybe not. When in troubleshooting mode, between Muphy's law and my spelling of "ASS-U- and Me" I try as best as I can to avoid both. 🙂 But, as you stated the odds are that it likely would have evaporated. More likely water got into the control board at the same time as on the heat exchanger. Water on the control board area would generally result in a unit failure. But then, I'm now making ASSUME's too. GJ 3 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
