dewdev
dewdev last won the day on June 17 2021
dewdev had the most liked content!
2 Followers
    354
    2018
    Aliner Expedition (Sold)
6,025 profile views
dewdev's Achievements
Mentor
Mentor (12/14)
  • Posting Machine Rare
1.2k
  1. @2008RN I belive the answer is yes. See the youtube video below on how to set it up.
  2. @HDRider Jeff: I do not think the bumper needs to be removed. On my OTT, Elite II, the trailer hitch receiver needs to be removed.
  3. @DBL-R I updated my post. Again, suggest that you call OTT to find out if you in fact you should have 3 Reverse Battery Fuses in place.
  4. @DBL-R Based on my 2018 wiring diagram, I have 3 - 25 (or 30 in your case) amp fuses which are called Reverse Battery Fuses. Strange that your system calls for 30 amp. As indicated in this post, check the batteries for property wiring and then check the Reverse Battery Fuses to make sure they are not blown. Not sure why you do not have 3 fuses in place. It might be a good idea to call OTT to confirm the 3 fuses in your Ollie are required. Good luck
  5. @topgun2 Did Mike say what product OTT uses to attach the bulb to the fiberglass? Thanks
  6. I agree, Yes a good part number to keep on file. Has anyone checked with OTT to see if they can provide the manufacutre name and part number?
  7. These southern storms are not good. At least the snow in the south melts fast (hopefully). The northeaster of this past Monday dumped 14" to 20" of snow depending of where you were in Maine, on top of an existing 6". The weater since then has been below zero at night and if we are lucky will get up to 20 degrees in the day. This morning it was - 3 degrees. Looks like this snow will be on the ground until spring time. In Maine we will miss the present northeaster hitting the southern states at this time. Hopefully Punxsutawney Phil tells us it will be an early spring.
  8. Not to change the subject line but: - 3 degrees this morning in southern Maine at 6:00 a.m.. Heat wave at 4:42 p.m. today at 21 degrees.
  9. The hatch that is mentioned to open is located at the rear of the trailer (if you have one- (it was a option)) that goes into the cellar (basement) storage area. The water feed piping from the campground water connection runs in this cellar (basement) storage area. The towel bar rack is in the bathroom. There are 4 screws (covered by the white plast covers). Take out the screws and remove the bar rack. The bar rack is likely held in place by some caulking.
  10. I purchased my Hypervent material on Amazon. I only installed it under my twin mattresses. Over 5 years, I have not had any problem with mattress moisture and it can get humid here in New England in the summer. In the winter, I do put the mattresses on edge on the hypervent material. I personnally would not overlap the hypervent. I have seen on the Oliver forum where some people have also installed it up on the sides of the mattress against the wall (I think even with the top of the mattress).
  11. @2008RNApprox 50% if storing for the winter months.
  12. Happy New Year to the Oliver family. Do people that have these Dozyant propane tank (in-line) gauges happy with them. Are they fairly accurate? Thanks
  13. @Tony and Rhonda Did you know that your attachment opens as a txt document, which is not readable?
  14. @Geronimo John@Wayfinder FYI, in my 2018 Elite II, hull # 354, the owner's manual for the ATS says it is a 30 amp unit, I think it is a model: PD5110010
  15. We have KTT mattress. It is very comfortable, but is heavy to move around.
