aaronorange
Everything posted by aaronorange
  1. We did replace the 400 amp anl fuse with a 350 amp. Also installed a Blue Sea disconnect. I’m using a 350 MRBF terminal fuse block at the battery (it’s on the back terminal in the photo). Some day I may add them to each battery. For those who have been tracking my initial issue with the 300 amp Optifuse that kept tripping. It turned out I had a bad crimp on that cable connection. But I prefer the upgraded protection. 🙂
  2. JD1923, I got ahold of Lithionics and they say MRBF Fuses are ok. They say I can do a single 300a fuse. This fuse attaches to the battery terminal. So protects right from the source. I also found out Xantrex recommends a 350a fuse max. So the inline 400a I put in for testing will be down graded to 350a if not removed. Thanks everyone for the help as I researched this issue.
  3. Mossemi- Sorry let me try to clarify, The Optofuse was between the 3 lithionics 130ah batteries and the 3000W Xantrex inverter/charger. (OEM from Oliver) My real question is does anyone use MRBF fuses, if yes what amp fuse are they using? Are they using one fuse or one on each positive terminal? Just wanted to see how others are handling the issue with the Optifuse breaker. I understand others are also having problems.
  4. How should I fuse 3 lithionics 130ah batteries wired in parallel when connected to a 3000W Xantrex inverter? I was having issues with the 300a Optifuse. I was told to replace the Optifuse breaker with a Blue Seas disconnect switch. I’m apprehensive not having a fuse inline. Would a 300amp Blue Seas MRBF terminal fuse be sufficient? I currently use a 400amp under the street side bed. I also plan to add the Blue Seas disconnect ether under the SS bed or in the battery compartment. Thanks!
  5. Do you live in a freezing climate? Will you keep you batteries heated? Will you keep your rig plugged into shore power? I would research those questions first. Lithium batteries don’t like to be charged in cold weather. You may want to remove your batteries for winter. I have kept mine in but monitor throughout winter for right temperature. As far as the Calmark cover, you can loosen the straps and lift the cover to get into the battery cabinet. It’s a pain especially in winter. It would be nice to have an access zipper flap added.
  6. I tried the Gas Stop but our propane generator didn't want to play with them. The Gas Stop see the the flow going to the generator as a leak and shuts off the gas. You probably have an automatic changeover regulator, your setup will automatically switch to the backup propane tank when the first one runs out, provided you leave both tanks open. That being said I usually only open one valve at a time and check my tank level by filling if its getting lighter. You'll probably get a sense of how much propane your using as you get familiar with your usage. Once I see the gage showing a sliver of red I'll change it. Haven't run out yet but I do watch it closely. I would suggest checking your propane hoses at the tank/regulator connection if you have any kinking or sharp bends. I put 90° elbows on mine when I added (tried) the Gas Stops and that made a major relief on the rubber hoses that from the factory have a pretty sharp bend in them.
  7. How many miles/days to the Grand Tetons? Nice looking set up! Enjoy the journey and welcome to the forum.
  8. We use a Zero water filter for drinking. Before our water goes into our sanitized holding tank we use the Blu Technologies water softener and the 3 stage filtration system. They sell filters that claim you can use lake or river water if you want to. Yep we are water snobs.
  9. We find that we leave the closet door open while camping it get stuffy in there hot in the summer and cool in the winter. No ventalation makes it stuffy, we do store our dirty laundry bag/hamper in there. We are contenplating adding ventalation. Has anyone else done this? What were the results?
  10. Update, I did eliminate the Tiwan made Optifuse and put in an inline 300 amp ANL fuse. Worked pretty good but the lug ends were heating above 130° (in a few minutes time). I went ahead and replaced the lug ends and the temp on those dropped 30°. Which confirmed my suspicions of bad crimps. Tested the Xantrex charger set to 150 amp as suggested by Oliver, the fuse will quickly heat up to 130° ish. (currently keep it set to 75 amp) When running the Truma AC which pulls 900 to 1200 watts and the fuse will get up around 138° and lugs 95°-112° (10 min. run). Not sure but guess these are normal temps. I had an RV solar technician tell me I could use a 400 amp ANL fuse since it uses 4/0 wire between the battery and inverter. I will test temps and research the use of a 400 amp fuse. Oliver sent me an email suggesting I remove the Opifuse and replace with a disconnect switch. I’m apprehensive about sleeping above an unfused wire. Thanks for all the suggestions.
  11. Got it, thanks. I think the soft start is a good idea. We will probably get one too. I was planning on doing some testing when I get home. I see Ray (in the video linked here) says his same inverter will load share, his generator will not start the A/C on its own. He talks about this towards the end of the video @ 16:36 min. He also uses a soft start. We had one on our Dometic AC but upgraded to the much quieter Truma.
  12. The Xantrex Freedom XC Pro 3000 inverter/charger load shares by prioritizing AC loads. It reduces the charge current to the batteries while maintaining the total input current below the breaker setting, ensuring that connected AC loads receive the power they need. This is particularly useful when running multiple appliances, including those with high startup surges like air conditioners. This video demonstrates how the Xantrex Freedom XC Pro 3000 handles various AC loads and its surge capability: 42s Love Your RV & Boat! YouTube · Jan 11, 2024 Here's a more detailed explanation: Prioritization of AC Loads: The Freedom XC Pro 3000 prioritizes the AC loads connected to it, ensuring they receive the power they need to operate. Charge Current Reduction: To accommodate the AC loads, the unit intelligently reduces the charging current going to the batteries. Input Current Management: It manages the overall input current, keeping it below the breaker setting, even when multiple appliances are running simultaneously. Example: If you have a 50-amp shore power connection and are using a 30-amp load, the charger might reduce its current to 20 amps to ensure the 30-amp load gets enough power. This video explains how the inverter/charger manages power distribution between AC loads and battery charging: 1m Love Your RV & Boat! YouTube · Dec 23, 2023 Load Sharing with Generators: The system can also work with generators, allowing you to run multiple appliances simultaneously, including those with high startup surges, by managing the power flow from the generator and batteries. Benefits: This load sharing feature allows for more efficient use of available power and prevents tripping of breakers due to excessive current draw. Example: You can run a microwave and an air conditioner at the same time, even if they are both drawing a significant amount of power.
  13. It is my understanding that the Xantrex 3000 Freedom Pro XC should be able to load share. So if your running the Honda 2000w generator with the inverter switched on and you start the air conditioner the inverter should make up the difference in the start up surge. You should not require a soft start. You said you had the large battery bank so my assumption is you have the 640ah batteries with the 3000w inverter. I run our Truma off the battery bank no problem. The generator we carry is 4000w propane, but I have been looking into using our 2000w Honda which is about half the weight. You may want to check with Oliver or Xantrex but I’m pretty sure it should work. There is a setting for transfer speed Oliver suggests it be set to “Appliance” 20ms but it can also be set to UPS 10ms. I would think that might be better but maybe someone more knowledgeable than me can chime in. I know in the past we have lost shore power and didn’t even know since the inverter takes over instantly. Which is why I keep it off until needed.
  14. When the 300A Optifuse trips only the A/C was running nothing else is running except maybe an LED cabin light. This has been an issue since day one. It pretty much forces me to use shoe power all the time. Any (inverter) microwave run time longer than 2min will also trip the thermal breaker. I have had it to the Oliver service center but Jason said he had never heard of the issue and did not have a solution. I don have a thermal temp gun but It is very hot to the touch both the battery wire and 300A Optifuse. This was a factory installation and there have been no modifications. 2022 built.
  15. At the time it tripped it was pulling 88 amps. This happened today, stopped at a rest stop for lunch and thought I’d give it another try. The A/c ran a couple minutes and then tripped. You’d think it would until the batteries were too low. Incidentally the batteries were at 100%. I charge them at 90A instead of the posted 150A. If the 150A charge setting is used it also trips the 300A Optifuse.
  16. Where is the moderator? 🤦🏼
  17. The patch idea is cool! Are those consecutive nights? We had 119 consecutive in 2024. Had a few long trips after that. We might break our record this year if we don’t stop over at home. 😎
  18. Thank you! Yes, I have triple checked all the connections for tightness. Including the post inside the inverter. I’m really puzzled as to reason why this keeps happening. Because of heat issues and potential fire I don’t want to just start changing parts. However if I get the okay from Oliver or Xantrex I will replace the Optifuse/breaker with a fuse. I would rather have it in the battery compartment for access. It’s always a pain to get under the bed to reset the Optifuse. Especially in the middle of the night. I was at the Texas rally last year and will be there this year as well. When we left last year we went to the factory to switch out our noisy Dometic A/C for the Truma. I asked the other Jason about my Optifuse issue and he said he had never heard of such a problem and had no solutions. We are headed to Murfreesboro for a ceramic coating this summer so maybe I will try stopping by Oliver.
  19. I have the Xantrex 3000 in a 2022 E2 w/390ah Lithionics. The 300A Optifuse continues to trip. This happens when the battery charger is charging while on shore power. Or when I run the AC at around 1000 ish watts on the inverter, it will typically throw an error 20 in that case as well. It seems to do short runs on the microwave oven (1 to2 min ok, haven’t tested long run times). As far as the inverter charger setting Oliver requires the Charger Current set at 150A. If left at 150A it trips. If I set it at 90A it seems to hold. We originally started with the Dometic A/C with soft start, same issue. Have since upgraded to the Truma A/C. Understand this doesn’t affect the charging side of the problem. I did open a ticket right after I bought it. Oliver sent a new Opifuse saying it must have been bad. Opened a second ticket but the issue goes unresolved. Is it possible the replacement Optifuse is bad? Any ideas? Thanks!
  20. Thanks for the great explanation! I’m still having issues with the original 300a Optifuse breaker. Once we get home to Tucson I will try a fuse. Is there any reason why I couldn’t use a 300A battery post fuse? It would seem to be easier to replace if needed. Of course there is already terminal ends under the bed near the inverter.
  21. That’s the same Optifuse breaker Oliver sent after I first reported the problem. Could I possibly have gotten 2 bad breakers? Back to the drawing board…
  22. Thanks, what exactly did you get as a replacement? I will order a couple. Thanks again
  23. My 300 amp optifuse keeps tripping when I try to run the Truma AC. It’s pulling around 800-1100 w when the a/c compressor runs. The fuse randomly but often trips. This is the replacement fuse/breaker from Oliver. They sent me a new fuse right after we bought it for the same issue. I was at Oliver last fall getting the Truma a/c installed and asked them about the constant Error 20 code but they had no idea. So this year I’m not getting the error code just the 300 amp Optifuse keeps tripping. And it is very hot when I reach down to reset. Tripped again today (5/21). Everything looks good and tight.
