Stevon Posted March 10, 2024 Posted March 10, 2024 I had a spring fail, so I decided to replace all four springs. In the process of replacing springs I realized that all four of my shocks had failed. I have about 35k miles on the trailer and was surprised that all four shocks had failed. Has anyone replaced the stock shocks with a higher quality product? 2021 Oliver Legacy Elite II Hull #845
Geronimo John Posted March 10, 2024 Posted March 10, 2024 Yes, lots and lots of good info at your finger tips. Try searching as below. GJ . 1 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
MAX Burner Posted March 10, 2024 Posted March 10, 2024 (edited) @Stevon - We replaced our's last year. The shocks were most likely OEM from when Oliver built it - if memory serves, 3 of the 4 were bad. We went with the same shock from Monroe - only difference was they're no longer yellow, they're black now. We'll be checking these new shocks when we replace the leaf springs in a couple weeks. They've got just north of 11k miles on them...FYI PS: It would be nice if you could add your OTT hull number and year to your signature block so other owners can better help answer any future questions you may have. Edited March 10, 2024 by MAX Burner Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Mountainman198 Posted March 10, 2024 Posted March 10, 2024 36 minutes ago, MAX Burner said: @Stevon - We replaced our's last year. The shocks were most likely OEM from when Oliver built it - if memory serves, 3 of the 4 were bad. We went with the same shock from Monroe - only difference was they're no longer yellow, they're black now. We'll be checking these new shocks when we replace the leaf springs in a couple weeks. They've got just north of 11k miles on them...FYI PS: It would be nice if you could add your OTT hull number and year to your signature block so other owners can better help answer any future questions you may have. Same here. One was bad so I bought a pair of the same model monroe. Could not find a better shock as nothing cross-references with it. Anyone have a better shock please provide make and part number 1 2021 Elite II, Hull# 898 2018 Toyota Tundra, 2003 Dodge Ram 3500 5.9l SRW
MAX Burner Posted March 10, 2024 Posted March 10, 2024 (edited) 6 hours ago, Mountainman198 said: Could not find a better shock as nothing cross-references with it. Anyone have a better shock please provide make and part number Dexter may have a suggestion for a better shock for the OTT running gear. I'll check with Mike at ALCON Springs tomorrow - he may have a suggestion as they do a lot of rock crawler suspension mods.... Edited March 10, 2024 by MAX Burner 2 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
