I had a spring fail, so I decided to replace all four springs. In the process of replacing springs I realized that all four of my shocks had failed. I have about 35k miles on the trailer and was surprised that all four shocks had failed.  Has anyone replaced the stock shocks with a higher quality product?
2021 Oliver Legacy Elite II Hull #845
Yes, lots and lots of good info at your finger tips.  Try searching as below.
GJ .
@Stevon -  We replaced our's last year.  The shocks were most likely OEM from when Oliver built it - if memory serves, 3 of the 4 were bad.  We went with the same shock from Monroe - only difference was they're no longer yellow, they're black now.  We'll be checking these new shocks when we replace the leaf springs in a couple weeks.  They've got just north of 11k miles on them...FYI
PS:  It would be nice if you could add your OTT hull number and year to your signature block so other owners can better help answer any future questions you may have.
Edited by MAX Burner
  • (SOLD) 2022 TUNDRA
Same here. One was bad so I bought a pair of the same model monroe. Could not find a better shock as nothing cross-references with it. Anyone have a better shock please provide make and part number
2021 Elite II, Hull# 898
Dexter may have a suggestion for a better shock for the OTT running gear.  I'll check with Mike at ALCON Springs tomorrow - he may have a suggestion as they do a lot of rock crawler suspension mods....
