rideadeuce Posted May 29, 2024 Posted May 29, 2024 Found this while looking for a shower head replacement. Might come in handy. https://itcshopnow.com/products/fontana-exterior-shower-adapter-and-sprayer-holder 2 2 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
Moderators topgun2 Posted May 29, 2024 Moderators Posted May 29, 2024 Handy indeed. A couple of years ago, Mossemi posted a similar device for use with an outdoor shower curtain he had designed. I've used mine a number of times. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
jd1923 Posted May 29, 2024 Posted May 29, 2024 (edited) Not always having good luck with suction-cup attachments, I went this route: JONKEAN White Handheld Shower Head Holder with 2 Hanger Hooks, Strong Adhesive Shower Head Holder, Adjustable Shower Wand Holder Wall Mount, Bathroom Waterproof Shower Handle Holder No Drill Need - Amazon.com The main plastic holder detaches and only a 1/4" thin clear piece left taped to the Oliver. During travel the holder fits nicely where the shower head is stored. I use it often! Edited May 29, 2024 by jd1923 2nd para 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
rideadeuce Posted May 29, 2024 Author Posted May 29, 2024 We use suction cups for everything. Flag poles, trash, paper towels, etc. Just have to have clean surface. Though, I like your solution. M 1 5 1 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
Patriot Posted May 29, 2024 Posted May 29, 2024 (edited) @rideadeuce All great suggestions! Thanks for passing them forward! Edited May 29, 2024 by Patriot 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderators topgun2 Posted May 29, 2024 Moderators Posted May 29, 2024 I really kike that garbage bag holder - neat, small and easy. Thanks! Bill p.s. assume that you found it on Amazon? 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
jd1923 Posted May 29, 2024 Posted May 29, 2024 1 hour ago, rideadeuce said: We use suction cups for everything. Flag poles, trash, paper towels, etc. Just have to have clean surface. Though, I like your solution. M Very cool, lots of good ideas here! Given suction cups can hold your flag, blowing in the wind is a testament for holding strength. My bias comes from those phone holders and other suction cup attachments designed for the truck windshield. One came with my gauges display. I mounted mine permanently below the dash. Once we get a shine on our exterior, it should work. Agree with Bill on the garbage can holder. I like the little one for interior use. Our interior fiberglass shines like new so should it maintain a good hold. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted May 29, 2024 Posted May 29, 2024 I went with a more permanent install on the paper towel holder and our side shelf is attached with magnet discs VHB to the side (shelf sits bottom of the attic when using the beds). The holder came with shaped tape to fit and after one outing it fell off. I cut 3M VHB 4950 to fit the small base and it's been holding even since. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
rideadeuce Posted May 31, 2024 Author Posted May 31, 2024 (edited) The spray head and suction cup mount were here when we arrived in Nashville. Side note: Remembered @Snowball had a terrific suggesting for getting ride of the black streaks from the OEM exterior light gaskets. Terribly frustrating. But he suggested using Capt Tolley's creeping crack cure on the gaskets and it worked like a charm!!!! Not more black streaks, just make sure you clean up when applying (hard to get off gelcoat once dry). So the whole reason I replaced the shower head was the freeze got it and it had a hairline crack at the head. SO walking back into the garage I saw Capt. Tolley's sitting on the shelf. Decided to apply it to the old head and see if it works. I will let you know. I also have used it to seal a window that had starting to fog up. Worked great there too. Thanks Snowball, wonderful stuff! Best, Mike Edited May 31, 2024 by rideadeuce 5 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
Moderators topgun2 Posted May 31, 2024 Moderators Posted May 31, 2024 Back in the day - Captain Tolley's was used by many Ollie owners on those black "gaskets" under the porch lights to help get rid of the "black streaks". At one of the early annual Owner's Rallies, Oliver gave everyone some aquarium sealant that the owner was to use to "seal" those gaskets so that they would not cause the black streaks. Shortly after this, Oliver eliminated the black gaskets and the source of the "problem" was simply eliminated. Great to see Captain Tolley's has other uses - hope it works. Bill 1 4 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
