Moderators Wayfinder Posted June 23, 2024 Moderators Posted June 23, 2024 Okay! It's time to get serious about ensuring all my electrical connections are tight enough. Over the years I've found quite a few lose connections in the old #110. Including nearly burned out connections inside the auto-switch box, very brown plastic bus bar. I don't know what is good or what is crap out there in terms of a "good-enough" torque screwdriver (or wrench). I've seen some reviews saying some are difficult to hold over a certain torque spec. Any experienced owners out there who could recommend something? Just enough to support anything in an Oliver. I don't need to get crazy with it. Thanks! 1 Chris 2016 Legacy Elite II o-o Hull #110 o-o "Rock'in 110" o-o Twin Bed 2020 RAM 1500 Limited 5.7L Augusta, Georgia
jd1923 Posted June 23, 2024 Posted June 23, 2024 Just make everything "good-n-tight" using hand tools and it's hard to go wrong. 3 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
MAX Burner Posted June 24, 2024 Posted June 24, 2024 (edited) Been using Fix It Stix for years and they're a great product. The T-handled torque wrench is the bomb - I wouldn't mount a precision scope or optic on any long-range rifle without it... just say'n. https://www.pewpewtactical.com/fix-it-sticks-review/ Edited June 25, 2024 by MAX Burner 2 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Jason Foster Posted June 25, 2024 Posted June 25, 2024 I've been planning to throw together a "tool kit" for my Oliver. I have a lot of tools, but I don't want to load up an entire professional automotive set when I will just need a few certain size wrenches, screw drivers, etc. So, I will start inventory on most of the nuts and bolts and select sockets that work. For the other stuff, I have a Kobalt screwdriver set with extension rods and multiple bits. I have never used a torque wrench on electrical connections. I just use the @jd1923 good-nuff technique and I have never had problems. However, if you want to get some tools, I suggest Harbor Freight. I have Snap-on, Matco, and the old Craftsman tool sets before China took them over. They have worked well and lasted about 35 years. They still look new. However, if you don't plan to use these tools professionally, Harbor Freight tools will be fine. 3 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Ronbrink Posted June 25, 2024 Posted June 25, 2024 4 hours ago, Jason Foster said: I've been planning to throw together a "tool kit" for my Oliver. I put these tool kits together soon after buying my 2012 Chevy 1500 4x4, which now serves as my current TV; where the Oliver goes, they go! The small individual pockets have assorted sockets and driver bits, as well as other accessories. 2 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
