Hi all -  I used standard twin sheets but they are getting to be quite annoying as we have the KTT mattresses that are heavy to move around for access so everything gets “ messed up “.
do you have recommendations for bed linens especially the fitted sheet.
We have 10" mattresses from Brooklyn Bedding: Dreamfoam Essential - RV (rvmattress.com) Ours are very comfortable and heavy too. Soon, we will cut a radius in one corner, so they will fit better, not being jammed in one corner.
Because they are tall mattresses, the standard twin fitted sheet works well due to the extra height. Chris is very much about a neat made bed. She uses Bed Sheet Straps the mattress protector and fitted sheets, something like these: Amazon.com: Gorilla Grip Bed Sheet Straps, Adjustable Elastic Fasteners with Metal Clips, Keep in Place Fitted Bedding Holder, Easy Install Suspenders Mattresses, Firm Tight Accessories, 4 Pack White : Home & Kitchen
I just saw this on a news feed I get.
https://products.buybedscrunchie.com/en/pre-1.html?loader=1&Affid=20827&s1=&s2=&s3=&s4=7424&s5=9bf83aa218f7436e97aca7abbd709e52&domain1=www.djpcraze.com&network_id=69
Do not own one, do not know how well they work, probably will not buy one, seeing as though Maggie bought sheets already.
If i find out where she bought them, i will post here.
maybe you could even make your own...   Hope the video comes thru.
B~Out
My Visited North America Map
@PMG Here is an entire thread dedicated to Oliver fitted linens. AB Lifestyles sells really nice sheets and mattress covers. And they are made in SC. 🇺🇸
Link -
https://www.ablifestyles.net/?network=x&device=t&keyword=&campaign=19268043787&adgroup=&gad_source=1&gbraid=0AAAAADm2yp4cMuAEZ67SUe_ub0u2nBxZ6&gclid=CjwKCAjw5Ky1BhAgEiwA5jGujjzxYHIsK_sqyIdIkTJqG89-YZJtvD-Kkydur9S87fAEcjd0kA2xrBoCT0wQAvD_BwE
Edited by Patriot
Bed Scrunchies are your friend. Shown using standard twin sheets on our KTTs. Stand on edge to make up. No problem when accessing hatch areas, sheets don’t get “messed up”!
2020 OLEll, Twin, 579:
Yes @Ronbrink has the right idea.
You could probably make your own custom fit bungie...
    1) some bungie shock cord,
    2) some of those under the sheet garters with elastic straps between the metal clamps.
Maggie recently bought some sheets (one R. & one L. opening) for our bedding, from,
    https://www.bunkbedsbunker.com/product/camp-bed-sheets/
The only issue, is the KTT mattress are too thick for them to stay 'snugged in'.  We ordered 6" depth, probably should have been 8".  they make > 8", but with a $20 up charge.
So I will be making our own bungie from some shock cord, and use the sheet garters we already have, and see how that works.
B~Out
