PMG Posted August 1 Share Posted August 1 Hi all - I used standard twin sheets but they are getting to be quite annoying as we have the KTT mattresses that are heavy to move around for access so everything gets “ messed up “. do you have recommendations for bed linens especially the fitted sheet. Link to comment Share on other sites More sharing options...
jd1923 Posted August 1 Share Posted August 1 We have 10" mattresses from Brooklyn Bedding: Dreamfoam Essential - RV (rvmattress.com) Ours are very comfortable and heavy too. Soon, we will cut a radius in one corner, so they will fit better, not being jammed in one corner. Because they are tall mattresses, the standard twin fitted sheet works well due to the extra height. Chris is very much about a neat made bed. She uses Bed Sheet Straps the mattress protector and fitted sheets, something like these: Amazon.com: Gorilla Grip Bed Sheet Straps, Adjustable Elastic Fasteners with Metal Clips, Keep in Place Fitted Bedding Holder, Easy Install Suspenders Mattresses, Firm Tight Accessories, 4 Pack White : Home & Kitchen 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins! Link to comment Share on other sites More sharing options...
SNY SD UP Posted August 1 Share Posted August 1 I just saw this on a news feed I get. https://products.buybedscrunchie.com/en/pre-1.html?loader=1&Affid=20827&s1=&s2=&s3=&s4=7424&s5=9bf83aa218f7436e97aca7abbd709e52&domain1=www.djpcraze.com&network_id=69 Do not own one, do not know how well they work, probably will not buy one, seeing as though Maggie bought sheets already. If i find out where she bought them, i will post here. maybe you could even make your own... Hope the video comes thru. B~Out 1 Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed Link to comment Share on other sites More sharing options...
Patriot Posted August 1 Share Posted August 1 (edited) @PMG Here is an entire thread dedicated to Oliver fitted linens. AB Lifestyles sells really nice sheets and mattress covers. And they are made in SC. 🇺🇸 Link - https://www.ablifestyles.net/?network=x&device=t&keyword=&campaign=19268043787&adgroup=&gad_source=1&gbraid=0AAAAADm2yp4cMuAEZ67SUe_ub0u2nBxZ6&gclid=CjwKCAjw5Ky1BhAgEiwA5jGujjzxYHIsK_sqyIdIkTJqG89-YZJtvD-Kkydur9S87fAEcjd0kA2xrBoCT0wQAvD_BwE Edited August 1 by Patriot 4 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor North Carolina 🇺🇸 Link to comment Share on other sites More sharing options...
PMG Posted August 2 Author Share Posted August 2 Thank you all for the info ! I look forward to tidy beds ! Link to comment Share on other sites More sharing options...
Ronbrink Posted August 2 Share Posted August 2 Bed Scrunchies are your friend. Shown using standard twin sheets on our KTTs. Stand on edge to make up. No problem when accessing hatch areas, sheets don’t get “messed up”! . 1 2020 OLEll, Twin, 579 No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, Hughes Autoformer, dual Lagun tables, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, Dreiha Atmos 4.4 a/c upgrade. 2012 Silverado 1500 4x4 A.R.E. truck bed cover/BedRug bed liner, 200W solar array/Victron SmartSolar MPPT 75/15 and 100Ah potable power station, Rancho QuickLIFT front suspension strut/coil spring upgrade, Advanced Technology vented/slotted disc brake rotor upgrade, Air Lift LoadLifter 5000 Air Suspension/wireless remote controller, Mechman 320A High Output alternator/upsize cables. Link to comment Share on other sites More sharing options...
SNY SD UP Posted August 2 Share Posted August 2 Yes @Ronbrink has the right idea. You could probably make your own custom fit bungie... 1) some bungie shock cord, 2) some of those under the sheet garters with elastic straps between the metal clamps. Maggie recently bought some sheets (one R. & one L. opening) for our bedding, from, https://www.bunkbedsbunker.com/product/camp-bed-sheets/ The only issue, is the KTT mattress are too thick for them to stay 'snugged in'. We ordered 6" depth, probably should have been 8". they make > 8", but with a $20 up charge. So I will be making our own bungie from some shock cord, and use the sheet garters we already have, and see how that works. B~Out 2 Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed Link to comment Share on other sites More sharing options...
