Hello fellow Oliver Elite owners! I am letting everyone know that the Highsierra company has made a handheld bathroom faucet with adapter (chrome or brushed nickel) that fits the original Oliver hand held bathroom sink faucet plus hose and I LOVE this design! This way you no longer have to replace the whole faucet housing while looking great and you'll only need to replace the handheld part by screwing on the adapter to both the original hose (will only connect to the hose with the female threads) and Highsierra handheld shower head. Due to this handheld design and being metal not plastic, I noticed when I showered that my hot water lasted longer during cold weather and the force of the water was stronger than the original hand held. If interested, below is the link to the handheld faucet and you can call if you have any questions. I hope this helps! Highsierra Shower Heads Company # 1-888-445-1941
https://www.highsierrashowerheads.com/shop/rv-handheld-olivtrailers/F
Edited by NomadLife
  • Like 7
Great thanks! Will the new faucet fit in the existing Oliver wall mount, or do I have to order the optional Highsierra wall mount?
**Sold😞**
Be aware that this adapter only works with older trailers. If you unscrew the faucet from the hose and the hose has a female fitting, it will work. The adapter has a female thread on the faucet end and a male thread on the hose end. Newer trailer need female threads on both ends. I’m going to have to send mine back.
Steve - Northern Ohio, USA
Facebook - Instagram
A follow-up to the above. I just called to return my adapter, and was told a new one is in the works for newer trailers, and should be ready by the end of the month. I’ll be getting one as soon as they ship.
Edited by Steve Morris
Thanks Steve, good to know, we also have a 2023 like you so I'll wait for the new one. Also,does the Highsierra faucet fit in the existing Oliver wall mount, or did you order the optional Highsierra wall mount?
**Sold😞**
It fits. Sort of two orientations it’ll drop into at different angles. For reference, the top is about 2” from the ceiling
I have the optional wall mount because I have all the components to do the separate shower valve and new faucet. But I haven’t gotten around to doing that yet. The adapter is a temporary step to use the shower head until I start that project.
  • Like 7
10 hours ago, NomadLife said:
September 10, 2024
Please add your signature to your profile.
I lucked out when installing the High Sierra shower head several years ago, happened to have a Kohler adapter that mated the stock hose to this upgraded handle. In ordering, don’t get too hung up on which flow restricter to choose (go high), the push button control valve can easily be used to reduce flow, as desired. The button is great for Navy showers, no more having to use the sink valve to regulate water flow and temperature; the button’s trickle feature keeps the water temp constant so no more waste of water having to reset, thus less volume in gray tank. As a sink faucet, I use the button to allow a reduced stream of water rather than full flow when the valve is opened, further saving water and tank volume. This product is a jewel of an upgrade, get one!
  • Like 7
  • 1 month later...
Great!  I hope this works out!
That's been more than a month ago since I was told that information. I've written back  without any response.
I would email them or call again.  I am sure they got busy and forgot to get back to you.
  • 4 weeks later...
I received my faucet adapter for newer Oliver trailers from High Sierra today. It fits great. It is made very well to boot!
If you have purchased one of these and need the adapter just go out to their web page (under Help) and submit a comment stating the year Oliver trailer you have and that you had already purchased their faucet but need the adapter for newer trailers (My 2021 E2 has a smaller, male fitting on the end of the hose).
2021 Elite II, Hull# 898
In a case of odd timing, I received mine yesterday, too. Just a day after I finish my bathroom fixture replacement...
I now have one of each style. If anyone has or will be getting a High Sierra shower head to replace the original Oliver pull-out faucet head (just the head, not the hose or entire faucet) let me know, and you can have either of mine free. The adapter with a male hose connection is for Oliver Travel Trailers pre-2021 and the adapter with a female hose connection is for the later model.  I can bring them in April to the rally, I'll be at the Eggs-n-S'mores rally in Florida in January, or you can pay to have one shipped to you.
https://www.highsierrashowerheads.com/shop/adapter-for-oliver-travel-trailers-chrome/
Steve
if it is still available we can use the adapter that fits the newer model 2022 Olivers
Let me know
Thank You
edit………..
after reviewing the High Sierra web page it appears that adapter is now included with the purchase of the shower head
in that case we wouldn’t need the adapter as we haven’t ordered the shower head yet
Edited by Tideline77
Robert E
2022 LE II , LIthium Pro, 2018 F150 XLT 4WD 2.7 EcoBoost , 355 gears, tow package,36 gallon fuel, factory brake controller, transmission cooler
Where are you seeing this on the web site? I just looked, and couldn't find it under the regular heads nor the RV/Marine heads. That would be cool if they did, but would add a lot of SKU numbers for all the RV and marine possible combinations.
Apparently they are making the shower head to fit both Oliver trailer configurations by year model
unless I am confused ? I stay confused 🤔
https://www.highsierrashowerheads.com/product-category/oliver-handhelds/
copy and paste email below
Hi Robert,
We will have a black Friday sale, but the discount on the Oliver shower heads won’t change from 15%. The shower head for your trailer is the one with a female hose connection:  https://www.highsierrashowerheads.com/product-category/oliver-handhelds/
Thanks,
David Malcolm
Tel:  888-445-1941
Robert E
Ah, you are entirely correct! That's a page I hadn't found searching their site. I'm sorry to confuse the issue.
It looks like the Oliver kits are $10 more than the head alone, which is probably a better deal than buying just the head and my cost to ship the adaptor to you. I recommend one of the kits with the trickle valve, to keep your water temperature consistent.
Enjoy!
  • 1 month later...
To all that have the Highsierra shower head, did you get the 1.25 or 1.5 gpm?
**Sold😞**
  • 6 months later...
Ron, can you give me the Kohler Adapter part number?
Thanks,
Gary Hull 292
2017 Oliver Elite II Hull 292
2018 Nissan Armada
Tampa, FL
Steve, I just saw this post. I’m replacing the hose/maybe the entire faucet in Hull 292. It was great seeing you at the Eggs-N-S’mores rally and Lake Guntersville. Do you still have the High Sierra? If so, I’ll buy it from you.
Thanks
Gary, Anita, and Ranger
2018 Nissan Armada
Tampa, FL
Thanks,
Gary Hull 292
Unfortunately no. The adapter I used was part of an old Kohler shower handle, and did not have a part number or any other identifying mark. It is my understanding however, that High Sierra now markets an adapter that is Oliver specific.
Edited by Ronbrink
Thanks
Thanks
Gary, send me a message with your address. We’re away right now, but when I get home I’ll see if I can find them. I recently cleaned my garage, and now I don’t know where anything is! 🤣
  • 4 weeks later...
