I’ve had the parts forever and between work and some travel, a list of injuries (that made it extremely difficult to kneel in the basement or crawl under the truck) I finally have this done, fully installed and performance tested! The bottom line is, “this charger is awesome!”
A month ago, I was working on waste valves under the front dinette seat when it occurred to me to run the charger cabling in the Oliver since I had everything opened. I always drill the smallest hole possible, no fancy cable glands for me. Two 3/8” holes would been enough, but I had grommets in a parts box 1/2" OD and 3/8” ID which were the perfect size. I glued them in place and afterwards caulked all of the cable openings front of hull (no pics taken).
It makes sense to wire the charger before mounting the board (pic1). The wiring is rather simple but the 4 AWG wire barely fits into the terminals. The 4 AWG wire will not fit into the Oliver ground/neutral bus, so I crimped on a lug and cut it to fit the opening. I installed the two grounds side-by-side (the other coming from the tow vehicle) (pic2).
When I worked my earlier inverter upgrade and rewiring projects, I had saved room for the new Orion DC-to-DC charger (pic3 close-up and pic4). The main + bus (in red) is protected by a 90A Marine Rated Battery Fuse (MRBF) that connects by 4/0 cable directly to the Victron Inverter-Charger bus and then through a 400A ANL fuse connected to the batteries (400A Victron Mulitplus spec).
All major circuits are connected to the main bus; the 40A breaker OTT installed for all the Oliver 12VDC circuits, two solar chargers (OEM Blue Sky for rooftop panels and a Victron 30A MPPT charger for a Renogy 400W suitcase) and the new DC-DC charger circuit which is connected through a 60A MRBF (see center of pic3). The secondary +bus (in black because I purchased a set) is protected by the OEM 40A breaker which connects to the 12VDC panel, the 3 jack fuses, etc. These are 8mm thick solid copper buses for minimal resistance. A considerable upgrade compared to the original OEM installation.
I attached the Anderson connection, front of trailer, and then got under it to see all the many zip ties that OTT installed. OMG, they should have better cable management! I replaced a lot of these because of age, but I did not want to merely zip tie this new heavy dual cable harness! Instead, I used the u-bolts that hold the front basket and cut brackets to support the cables including the trailer harness in two places, in front and rear of the basket. The picture shows the front bracket (pic5). And after taking this picture I hammered both ends of the bracket to curve them up almost touching the upper bracket to create a D-shape. I could have purchased pretty brackets, but these were on hand, fully functional and can only be seen while lying on the ground!
The trailer side installation was then done! When I finished and reconnected the house batteries, the blue light on the Orion started blinking and it was listed as a device on the Victron Connect app. So before even working on the tow vehicle installation, I was able to update the firmware and configure the Orion charger. I reduced the output charge to 30A for safety concerns and initial testing. The battery settings were close enough, within 0.1V of the specs for Epoch LiFePO4 batteries.
Next is the tow vehicle side installation. The Ram Cummins and most diesels have dual batteries. I chose to connect to the RHS battery since there are less connections, because its proximity to the alternator, and because I wanted a straight run down the frame to the RHS of the rear bumper. Looking ahead, last year I installed a custom Nations 180A HD alternator. OEM rating on our truck is 130A, thus gaining 50A for charging ampacity!
Starting at the battery, I ran the B+ cable along the fender rail to keep it away from the heat of the exhaust manifold and entered the main frame member just behind the engine. Conveniently, there are two holes in the frame just behind the front wheel (pic1). The RH opening is where it comes from the engine and the LH is where it continues all the way to the rear wheel. I had 100’ of 1/2" automotive loom from a past project which made for a clean installation! I removed the RR wheel for ease of access in running the cable. It took a couple of wire ties to get up and over the rear wheel-well but mostly the 4 AWG cable just lies nicely inside the frame beam, very well protected.
I decided it should come out below the rear bumper yet above the trailer hitch. The Anderson SB175 connectors are huge (pic2). A full inch or more of bare wire is required inside each pole connector, so I crimped each in two places. There are a series of holes across the bottom of the rear bumper. I used the two holes closest to the center, fabricated and simple bracket to hold the heavy environmental boot in place (pic3). This worked out great as you can push in and pull out the trailer side connection with one hand and it does not budge! So, I have the trailer harness connection on the left and the DC-DC cables on the right (pic4). It looks clean, nice and balanced.
Many on this forum and elsewhere believe you need both B+ and B- 4 AWG (minimum) wire running all the way end-to-end! This is certainly true for the B+ cable. For the B- cable, I merely ran a 2 ft length from the Anderson coupler grounded to the rear frame. I believe an 8” section of steel frame will produce less electrical resistance than 4 AWG copper and testing showed this to be either true or “good enough!” I ran another short 4 AWG ground wire from the B- battery terminal to the front of the same frame member.
Last step was to connect the B+ charger cable and reconnect the battery terminals. I used another 60A MRBF for the main run (pic5). I also ran short cable from the B+ terminal to the alternator (for redundancy, this connects the charger B+ to both the alternator and batteries with new 4 AWG copper). I’ve never seen anybody take these extra steps, but I believe it will provide better charging performance. You’re running 4 AWG everywhere else, but OEM cables from battery to alternator are usually only 6 or 8 AWG and solid grounds are often an automotive issue. BTW, OTT only installs one 6 AWG ground wire for everything running on DC! I added a second 6 AWG ground cable from the negative bus in line to the batteries in a previous upgrade.
This should work great, I really liked how it turned out. I measured carefully and purchased only 65 ft of black 4 AWG wire (not bad for wiring an extended cab long bed pickup truck tow vehicle)! I used all of it, and every run has slack on both ends and the trailer side connector is 6” longer than the standard hitch coupler cable.
I ran thorough testing today and I'm getting 40A charging output with the Cummins diesel running at idle! Yes, engine running at idle. I captured pictures of all the Victron Connect screens showing Orion and Smart Shunt data. I'm getting rather tired tonight, so to do this reporting justice I'll get all my data together and add another post tomorrow. As I opened my thread above, "this charger setup is awesome!"
  • Love 2
Excellent write-ups on your DC-DC install! Looks like you have it dialed in for peak efficiency, waiting to learn more on its awesomeness! I too ‘home shop’ for spare parts and materials to complete any given project, definitely saves time and money. When I did the alternator upgrade on my former TV (Mechman 320 Amp High Output Alternator) I installed the Big 3 wire upgrade, which substantially improves grounding at the alternator, engine and frame using 1/0 cables. However, I have since stripped said alternator and cables from the Silverado 1500 for future install on the Savana 2500, which has a 150 Amp stock alternator that will suffice for now. I’ve already done the same with the formerly installed DC-DC cables on the Silverado and the Savana is now readied with the rear bumper Anderson SB120 connector and Source Side Environmental Boot/Cover.
Edited by Ronbrink
At start of the performance test, the 600AH Epoch Essentials LiFePO4 batteries were at 100%, rooftop solar sitting in the midday Arizona sun. So, I started the A/C on inverter. It was a mild day low 60s. I set the thermostat down to 55F, opened the windows so no cold air would collect inside and just 34 minutes later SOC was down to 86%, with the old compressor of the noisy Dometic PII running continuously.
I also warmed up the tow vehicle and after 25 minutes idling the gauges looked like this (pic1). Engine Coolant Temp (ECT) was up to 160F (190F is fully warmed up). The idle engine speed at 800 RPM and battery voltage held steady at 14.1V. I did not take a second picture but when the truck was connected to the DC-DC charger, voltage read 13.8V on this gauge.
At first I had configured MAX charge to 30A and took a reading and quickly reconfigured it to the default 50A max charge. Below are the two screenprints, shown left to right (pic2). Set at 30A MAX, 30A was received and 30A also in output. Set at 50A max, the charger output was 40A. This must be due to the 800 RPM idle speed. At highway speeds, the Cummins is generally about +/- 1900 RPM so the HD alternator should produce both higher voltage and amperage.
Again, voltage measured at the truck was 13.8V and when the charger was set for a 30A it read incoming voltage at 13.6V, a -0.2V voltage drop. When producing 40A, the Orion read 13.2V, a -0.6V drop. Is this voltage drop along the wiring?
And I do not understand the lower voltages produced on the output side, as I would think the Orion charger would output higher voltage in the range of 13.6V to 14.2V to the batteries. Maybe Geoff @Snackchaser knows, how does this makes sense? The 30A charge looks fully efficient. Set at 50A I got 40A idling at 800 RPM. The final test, I will run start of your next trip, will be to test the 50A charge setting at highway speeds. All this was done sitting at idle in my driveway. More to come…
I needed to verify numbers showing for the Orion Charger are relative to what the Victron Smart Shunt was reading at the batteries. The screenprints (Orion vs. Shunt) were as follows (pic1). Why does the Smart Shunt showing 10A more? Because the Blue Sky solar (pic2) was adding +12A and the remainder -2.3A is used for inverter standby overhead, exterior Courtesy Lights (always on) and some parasitic. These numbers add up nicely!
Last test for now...
What if when boondocking, far from hook-ups and other campers, you're needing A/C on a HOT afternoon, and your batteries getting low? You could start and connect the tow vehicle to the DC-DC charger. Diesels can idle forever using little fuel.
The truck alternator via the Orion charger could supplement inverted power to the A/C for some period of time. The approx. +40A noted before at idle should offset the AH used by the A/C system. These readings (pic1) show this to be true, +39A were being supplemented by the charger at this point in time - nice!
Also notice, the Time Remaining stat increased from 2 1/2 hours to 4 hours given the lower AH usage. I will eventually install an A/C that uses much less power than the Dometic PII. That's all folks.
Edited by jd1923
JD, This is way overy head. I'm actually having a good chuckle
 I want to see all of this when we see each other next. 😊👏👏
Yes John, you and Susan, and your wonderful, infamous Jolli Olli, please come see us on your 2025 western trip!
We have power and water hook-ups for those who are off-grid challenged 🤣, and a dump station just down the steet!
It would make our day, no, it would make my year to see Y’all in Prescott Arizona! God bless
Edited by jd1923
Update on my installation of the Victron Orion XS 50A DC-DC charger.
I believe this suggests frame mounting the ground on the TV works fine and saves purchase of another 15-20 ft of expensive 4 AWG copper!
The picture tells the whole story. The charger set to the max 50A charge setting outputted 47.4 amps.
I took this picture just 50 yards out of our driveway, climbing up our steep road as soon as the RPMs got up to the high teens. 40A at idle and near the full 50A while towing! Our batteries were near full SOC so the charger soon geared down to less than 10A.
After 3 days Boondocking in the Prescott NF, batteries at a lower SOC, we’ll see how many AHs are gained driving home, a 90+ minute drive. Solar should handle the Dometic fridge on DC and the Orion should produce a net increase in SOC.
After 3 days out boondocking, I tested the Orion XS 50A DC-DC Charger while driving 90 minutes to return home. SOC increased from 57% to 66% (9% of 600Ah). Ahs gained were 53.8Ah (271.8 - 218.0) or 36Ah per hour (pic1). I'm assuming the 10-12A generated from the solar charger covers the fridge on DC and +2A for our Inverter on standby, etc. It was a mostly sunny day with some haze.
We started back on 20 miles of dirt roads, some washboard, then 20 miles paved roads. Our speed ranged from 10 to 50 MPH. I would consider it more equivalent to suburban driving, certainly not highway driving. The highest output charge rate observed was 47.8A early but most of the time it sat somewhere in the 30s. Battery voltage started at 13.10V and 13.35V ninety minutes later. Highest output charge voltage was 13.7V (pic2), even though it was configured up to 14.2V in the setup.
I have an accurate voltage gauge in the truck measuring voltage at the starter batteries. With any amount of fuel pedal, it will most often read 14.2V. After I connect the DC-DC charger this reading drops to 13.8, then 13.7 and back and forth. Let's call it 13.75V. The difference between this and the input voltage of 13.1V (on Orion charge screen) shows a 0.65V voltage drop (TV batteries to input side of charger). This is likely normal for the length 65' of 4 AWG copper wire and 16' of the TV frame.
That's all I got for now. In 3 weeks we are heading to Albuquerque and with some boondocking on the way home. It should be about 1,000 miles total. The real test will be in June, 4,000 miles in a big loop from AZ to MN and back! This is sure a great investment at $540 parts plus a day of labor.
  • 3 weeks later...
First highway test today. Left home today and drove 175 miles to Holbrook AZ. We went mainly state highways, drive-time of 3:10 hours, an average of 55 MPH.
We started at 59% SOC (600 Ah total) since we had started the fridge on DC about 40 hours before departure. Just after we arrived we had 81% SOC. That's +132Ah in charge or 41.7Ah per hour charge rate. However, the Orion on the Victron app never got above 38A and was more often running at 35A. This means the Blue Sky SC and 320W solar was supplying the DC power to run the fridge and net close to +7Ah. This is so cool!
Tomorrow we will arrive in Albuquerque and since it is about 240 miles I'm thinking will be pretty close to 100% SOC. I'm never going to worry about our batteries when we have a half day or more on the road again!
JD, running your fridge on dc and only 175 miles worth of charging... I'd say you're doing quite well!  We've only used our charger twice since seeing you in Quartzsite.  And we boondock more and more often.  I do take advantage of solar with my portable and I'm happy to have the dc to dc charger as a backup for extended cloudy days...thankful I installed it for that reason :)  Congrats on your successful project!  It's sooooo nice to not worry about battery usage with the lithiums and having another backup plan through the charger!
Happy Trails,
Day two, 244 miles in  under 4 hours, mostly on I-40 at 70+ MPH. SOC increased from 56% to 82% (26%) or 156 Ah. Tonight and last night we ran our Emeril Air Fryer for 20-30 minutes (too windy to cook outside), fridge on DC most of the time which brought 600Ah down to 56% (fridge on DC overnight SOC would have been about 50%).
Today on the road we charged 40Ah per hour. Yesterday it was near 42Ah. Likely 40Ah gained per hour is something I can count on with the Orion XS 50A DC-DC charger as I have it wired. If you drive a long day (7.5 hours with engine running) you can charge a full 300Ah! That and 720W solar, I'm thinking we no longer need 30A hookups. Very nice not to need to plug in. Carrying 35-gal extra water in the TV and it's only time between dump stations that bring us back to civilization, that's amazing. 😂
We just got back from our Albuquerque trip and it was our first outing with real highway miles, about 1000 miles roundtrip over the last 12 days.
We are now getting BETTER performance with our Orion XS 50A DC-DC charger. I have seen charge rates often at 45-47A and once 48A was observed!
Check out these pics. As soon as I read total charge of 58A (see 57.74A on right side) from the shunt reading, I switch to the Orion reading asap and it was at 46A (46.1A on left). The fridge was on DC but likely not pulling amps at the time, so the Blue Sky charger with 320W rooftop was supplying the extra 12A.
We were at 59% SOC (of 600Ah) when leaving after two nights and was up to 82% when we arrived at our next camp. A 58A charge rate is likely the best case scenario, but no more worries about battery SOC%. You gotta get one of these!
Looks like you have the Orion dialed in! Good to see how it and your rooftop solar play together.
  • 1 month later...
I really thought I was done with this thread, but the engineer in me thought of a new need today, given the current heatwave across the country, currently bothering our trip!
Mike @rideadeuce gave me the idea and I was skeptical at first, like driving 8 hours cooling the Oliver while keeping your dogs in the trailer or something. I believed highway speeds would pull any cooling achieved right out of the trailer and down the road, like a boat leaving the wake behind it. On this account, I was wrong. 🤣
For the last of couple weeks on our road trip I have used our Victron inverter to not only run the fridge while driving (LP tanks off of course), but also to power the HWH. For the last few weeks we have arrived at our campsite at 100% SOC, fridge cooled and water hot upon arrival, by running our DC-to-DC and solar chargers running.
So today it was to be in the mid 90s for the 3rd day, OMG in northern SD and WY! I turned off the breaker to the HWH and set the thermostat low on our (POS) Dometic P2! Got back in the truck and towed our Oliver 90 minutes to our destination.
I still cannot believe the results! In 90 minutes our cabin temp dropped 10F. This usually takes 2-3 hours with the P2 at the campsite after connected to shore power. The only explanation I could think of is that while driving at highway speeds the A/C condenser gets cooled much more efficiently. We used 216Ah in this short 90 min out of our 600Ah total (36%).
It was totally worth it! We arrived at camp at 4PM with a COOL cabin. Those of you who run an inverter and study your inverter and battery apps, check out and spend a bit of time with these screen-prints. You can see that outside it was 93F when we started at 2:30PM and 94F by 4 PM (Ruuvi sensors), while the interior temp dropped from 85F to 75F. Get me one of those inverter A/C units and we can likely do this using 100Ah! No, you cannot run it all day with dogs onboard. 🤣
