John and Debbie Posted May 24, 2025 Posted May 24, 2025 Colorado roads are some of the worst. We were on I-70 from Grand Junction to Denver today. When we got here I noticed the bottom of the window frame by the dinette is loose. We did get Alcan springs on Tuesday, but we had some good sized dips on the freeway!! Is that an easy fix to get that frame tight again? John 1 1 John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Alcan 5 leaf springs and Bulldog shocks done May 20, 2025 in Grand Junction, Colorado
Patriot Posted May 24, 2025 Posted May 24, 2025 (edited) 6 hours ago, John and Debbie said: Colorado roads are some of the worst. We were on I-70 from Grand Junction to Denver today. When we got here I noticed the bottom of the window frame by the dinette is loose. We did get Alcan springs on Tuesday, but we had some good sized dips on the freeway!! Is that an easy fix to get that frame tight again? John John, Sorry to hear this news, and its the first I have heard of a window frame coming loose. Can you provide any photos? Edited May 24, 2025 by Patriot 2 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
routlaw Posted May 24, 2025 Posted May 24, 2025 (edited) 9 hours ago, John and Debbie said: Colorado roads are some of the worst. We were on I-70 from Grand Junction to Denver today. When we got here I noticed the bottom of the window frame by the dinette is loose. We did get Alcan springs on Tuesday, but we had some good sized dips on the freeway!! Is that an easy fix to get that frame tight again? John John if I understand your description properly you should be able to snap off the shade first. Pull from the bottom then lift off from the top. Once the shade is off the frame you should see several nuts around the circumference of the window frame. Before tightening those you might need to apply some caulk between frame and Oliver body. This shouldn’t have happened regardless of road conditions but should also be a fairly easy fix, albeit an aggravation. My guess is a few screws/nuts were not completely tightened during the build and vibrated loose. Good luck Edited May 24, 2025 by routlaw 1 2 Legacy Elite II #70
Moderators mossemi Posted May 24, 2025 Moderators Posted May 24, 2025 10 hours ago, John and Debbie said: When we got here I noticed the bottom of the window frame by the dinette is loose. Just so I have a clear understanding of this issue, is it the frame of the window shade or the actual window? Mossey 4 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
John and Debbie Posted May 24, 2025 Author Posted May 24, 2025 2 hours ago, mossemi said: Just so I have a clear understanding of this issue, is it the frame of the window shade or the actual window? Mossey John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Alcan 5 leaf springs and Bulldog shocks done May 20, 2025 in Grand Junction, Colorado
rich.dev Posted May 24, 2025 Posted May 24, 2025 @John and Debbie Is it the window frame (black arrow) or window shade (red arrow) that’s loose? 1 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
John and Debbie Posted May 24, 2025 Author Posted May 24, 2025 It's the window frame, the red arrow in your picture. John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Alcan 5 leaf springs and Bulldog shocks done May 20, 2025 in Grand Junction, Colorado
rich.dev Posted May 24, 2025 Posted May 24, 2025 18 minutes ago, John and Debbie said: It's the window frame, the red arrow in your picture. The red arrow is not the window frame, it’s the window shade. Here is an Oliver video that shows how the window shade is removed/secured. 2 2 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
John and Debbie Posted May 24, 2025 Author Posted May 24, 2025 28 minutes ago, rich.dev said: The red arrow is not the window frame, it’s the window shade. Here is an Oliver video that shows how the window shade is removed/secured. Thanks Rich, it looks easy to fix. I see that I used the wrong term. I meant the window shade. Thanks again for finding that video. John 3 John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Alcan 5 leaf springs and Bulldog shocks done May 20, 2025 in Grand Junction, Colorado
rich.dev Posted May 24, 2025 Posted May 24, 2025 (edited) I see there’s a bit of a gap between the window frame and inside wall (black arrow), when you have the shade removed check to see if the screws that secure the window frame (red arrow) to the main window are not lose, but pay attention not to over tighten them, they strip easily. Edited May 24, 2025 by rich.dev 1 2 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
John and Debbie Posted May 24, 2025 Author Posted May 24, 2025 1 hour ago, rich.dev said: I see there’s a bit of a gap between the window frame and inside wall (black arrow), when you have the shade removed check to see if the screws that secure the window frame (red arrow) to the main window are not lose, but pay attention not to over tighten them, they strip easily. All looked good. I was able to snap the window shade back in after checking that the connection points were secure. Thanks for the help. John 4 John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Alcan 5 leaf springs and Bulldog shocks done May 20, 2025 in Grand Junction, Colorado
