Just had Alcan redo our Hull 505 with new springs. Here's a video showing how they make the springs...starting at 1:14 mark for about 2 minutes.
After a spring replacement with an Alcan 4spring pack we need to retorque nuts.
Q)  What size sockets are needed to tighten all the nuts after a spring replacement from Alcan?
A) Here is the detail from Alcan:
You need a 22mm or 7/8” socket and 150ft-lb torque wrench for Ubolts and inside shackle bolts
Use a 21mm or 13/16” as backer wrench or standard depth socket on nuts outside of shackle.
Mileages:
Retorque u-bolts & shackles at 50mi,     100 mi and 500miles after installation, then yearly check.
Torques Values:
 U-Bolts   90 ft-lbs
Shackles:  65 ft-lb
(Note - use 21mm or 13/16” backing wrench on outside of shackles)
Also check lug nuts to wheel specs at each interval as well.
Edited by Galway Girl
Answer & video
7/8 for both the U bolts and the shackle bolts. Both U bolts and shackle bolts are 9/16 diameter so the wrench size for this standard nut size is 7/8. You will need a deep well socket for the U bolt nuts. I have a deep well 7/8 socket for my truck wheels so this worked perfectly.
2017 Elite II, Hull #208
2019 Chevy HD 2500 Duramax
Craig, besides the 7/8” deep socket Ken mentioned, a 13/16” socket might be needed to hold the front side of the shackle wet-bolts if they were to slip. A deep-well socket may be needed here too to fit over the Zerks.
The other day, the bolt holding the equalizer to the center hanger was spinning on mine. Using 13/16” socket and short extension, the breaker bar hanging between the tires, I was then able to tighten/torque while the tire held the bar in front! 😎 (thought at first, I would need to ask Chris to hold the front side).
Nice for Ken, 7/8” works for all! I need 15/16” for Dodge wheels and 3/4” for Oliver wheels. I bring all sizes from 1/2” to 15/16” in deep-well 1/2” drive impact sockets and the same sizes in short sockets 3/8” drive. Also have 1/2” to 3/8” and 3/8” to 1/2” drive adapters to use any socket in any ratchet, ratchets in all sizes, and a 1/2” breaker bar that fits into a 2 ft cheater bar!
I want to be able to make repairs like replace a water pump/serpentine belt on the road, change Nev-R Lube bearings (see thread on that with tools listed), most auto repairs.
That should do it! 🤣
9 hours ago, Galway Girl said:
After a spring replacement we need to retorque nuts.
I’m going to try and get all the right sockets ahead of time.
Thanks
This may be of help. You will definitely need deep well sockets for the Ubolts.
Edited by Patriot
  • The title was changed to Alcan nut sizes for tightening updated
