DanielBoondock Posted September 27 Author Posted September 27 On 9/25/2026 at 5:54 PM, jd1923 said: Love this tool. Mine sits on a shelf in our garage. No case, not towing with it. Also got the LockNLube coupler. I wipe the nozzle and each Zerk fitting clean after every squeeze of the trigger. Getting a tube of grease in any gun, manual guns too, is always a struggle, not easy to get the spring back in on a full tube. I don't know of any tricks, just push down on the workbench. Never tried bulk grease. I purchased a 10-pack of red #2 wheel bearing grease a few years ago. Compared to my last one DeWalt puts in a much stiffer spring so it's a bear getting the pusher in. I've gone all-in on your approach, or will soon. Trying to find where I put those 45 zerks to finish it off. Also have the LockNLube. How well does this work with the Alcan, do you find you need to lift the camper to relieve pressure and get grease in? Unfortunately I'm not super confident that all the grease holes are horizontal, they might have shifted in installation. Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 530 mile pack)
DanielBoondock Posted September 28 Author Posted September 28 First re-torque of the D-bolts, surprised at how much they stretched, And looked what I noticed, check the marks on bottom of the frame this isn’t Alcan which has only done 30 and barely moved by the trail cam, it’s Dexter. In only 4k miles that flabby old suspension banged (HARD) against the frame, bottoming out. Might as well hit your trailer with a huge sledge hammer. I suspected it was bottoming out, that seems like they’re practically inverting. No wonder those springs break 🙄 1 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 530 mile pack)
jd1923 Posted September 28 Posted September 28 On 9/27/2026 at 8:07 AM, DanielBoondock said: Compared to my last one DeWalt puts in a much stiffer spring so it's a bear getting the pusher in. I've gone all-in on your approach, or will soon. Trying to find where I put those 45 zerks to finish it off. Also have the LockNLube. How well does this work with the Alcan, do you find you need to lift the camper to relieve pressure and get grease in? Unfortunately I'm not super confident that all the grease holes are horizontal, they might have shifted in installation. Yep, no fun, it's quite a push. Just installed the 3rd tube in my 1st-ever power grease gun! Though once ya get er loaded, it’s a dream! 🤣 And thank you, Dan. You reminded me to do the grease/torque job, after a bit of travel and conveniently when our Oliver was sitting in the driveway hitched. It's my "first annual maintenance" since our suspension upgrade. Took me an hour each side. I lift the tires using the one leveler jack and remove the 2 wheels first, always. She's in my driveway, I have the air tools, so zip-zip off. If you don't have the HD compressor and pneumatic impact get the HD Dewalt 1/2" impact (compare torque ratings before purchase). Don't worry about installing wet bolts outside-in like some do, or using 45-degree Zerks as I had. The standard installation is just fine when you take the wheels off first. Inspect the tires too while removing gravel from the treads. Test brake amperage. Don't I have a thread on this? (linked below) I don't use dust caps on the Zerks anymore. They just collect dirt. I steel brush all the old grease & dirt off first. Then wipe with paper towels and after greasing use a screwdriver and my fingers to get ALL the grease that oozed out of every opening. It is a messy job. Grease first, torque second and YES with wheels off a lot of weight is off the suspension and it's lightly hanging. This time all wet bolts took grease without fiddlin' with them! Last time I had to loosen 2 wet bolts to get them to accept grease. I only needed a second wrench on one wet bolt to keep it from spinning while torquing; the others held on their own meaning they held in place since last maintenance. Only two U-bolt nuts, 2 out of 16, needed tightening at 95 ft-lbs and the two only moved an 1/8th turn each. The others were set, slightly rusted into place. All the parts including the Alcan shackles are like new, with no observable wear. I’d say that after one full year with an estimated 5,600 miles towing, our new Alcan-D52 axle suspension has broken in well. 😎 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
DanielBoondock Posted October 11 Author Posted October 11 Finished off the SiO2C6 coating! Took one 250 ml bottle exactly for two coats over the whole trailer, including two Seafoam storage boxes (tops), two awnings and various metal bits like the doorstep. Except for the solar panel, mainly I want to get that bug catcher front edge but will do the top too. But I bought the 30' new trailer kit which has two bottles. What to do with the unopened second bottle? Once a bottle is opened it needs to be used within a month or so Option One: Inside I'm considering doing the inside too, at least strategic parts of it. The bathroom is a prime candidate to make shower cleanup easy. The countertops too, they're a thick gelcoat I believe which picks up fine scratches. I'll do a small test and see how well that works out. The floor rounded edges along the aisle is a prime candidate, those take a lot of wear. I've been waxing them but that doesn't really do a lot honestly. Checking with an AI opinion, Gemini is saying 'yes you can but generally not recommended'. Main reason being the solvent fumes (I have 3M cartridge chemical respirators and we have the ceiling fan), and basically its overkill, which is reasonable. Presently I'm using DuraGloss two step - base marine wax with a quick clean touch up, which works OK but not like a silicon coat. Option Two: Refresh coat Other option is to save the bottle (storage temp is important) until the next year or year and a half, and apply a refresh top coat. I think I'll do this Procedure (notes to my future self) Use that unused bottle of Glidecoat nano wash (deep chemical wash) Check the surface, rough spots (previous coating glitches) and scratches Use leftover SONAX EX-04-06 with foam pad, 4500 RPM, three passes crosshatch Two towel wipe off 3'x3' sections Alcohol/GC Surface wipe two towel Apply coating in a cross hatch pattern, let flash 30-60 seconds Two towel leveling (wipe off cross hatch, second towel in a circular method) Also do the missed parts Underbody (why not I've got plenty to use up?) Solar Truma plastic covers Front door, door step aluminum and other exposed aluminum Rear bumper metal 2 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 530 mile pack)
jd1923 Posted October 12 Posted October 12 (edited) On 10/11/2026 at 7:05 AM, DanielBoondock said: I'm considering doing the inside too, at least strategic parts of it. Good job, Dan! You're a better man than me, as I gave up buffing/waxing before ceramic coating was a thing. 🤣 IMHO, skip the interior. Our Hull #113, without any real maintenance, still has a beautiful shiny interior after 11 years. I have a few spots, I would like to correct, like where somebody had to put their shoes above the bed area. Anyway, the interior stays pretty shiny without much effort. Edited October 13 by jd1923 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
DanielBoondock Posted October 13 Author Posted October 13 Oh back in the day I never buffed/waxed anything, except windshields occasionally with wax (and now ceramic). Too much work for something that doesn’t last - ceramic changed all that and this is my first use of it. The Ollie is special though, my prized possession. I’m trying to keep it as pristine as possible. 3 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 530 mile pack)
DanielBoondock Posted 7 hours ago Author Posted 7 hours ago (edited) Here on the upper West Coast we can get incredible amounts of damp, cold humidity. The little Peltier dehumidifiers don’t work worth beans, and using your AC just puts on the freeze. So I took a chance on the Media Cube 20 pint. https://www.amazon.com/dp/B08ZMY8BC8 Fits nicely between the twin beds, I’ll just keep it there by the bedside table which is a great spot. Note in tank mode it blocks the door, I’ll look into a drain hose sometime (OTOH it won’t be on every trip, mostly likely I’ll just bring it along based on where we’re going). So anyhow not for summer humidity - just use the AC - but for winter humidity this works perfectly. It acts like a little 200W space heater, is pretty quiet and pulls an enormous amount of water out of the air. When traveling or storing the top half nests inside the lower half tank. Edited 7 hours ago by DanielBoondock Add image 1 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 530 mile pack)
Snackchaser Posted 4 hours ago Posted 4 hours ago 3 hours ago, DanielBoondock said: Here on the upper West Coast we can get incredible amounts of damp, cold humidity. I hear that! Here in the West Coast redwood rain forest, we found a KNKA Energy Star 80 pint unit thats small enough to sit on the kitchen counter and drain into the sink. We don’t take it with us on road trips though, a couple of paper towels is enough to remove the moisture from the Oliver's factory window condenser units! 😂 Cheers! 2
