We are on the road, maybe another day to home.  I don't use our awning very much because it seems there is always too much wind and it retracts on its own.
I do put it out from time to time just to make sure it is working and to let it air out after a rain.
I put it out this morning.  Left it out for an hour or two and put it back in.
When it went in I did not hear that little clunk as it finished retracting.  Looking at the front of the awning it looks like it is not going all the way in, maybe lacks a half inch or so.
The first pic shows it out.  The second pic show the back of the waning.  It is all the way in.  The last pic show me pushing the front in.  It goes in with a push.
Am I imagining this?  Or is it not right?  Lastly, am I OK driving another 600 miles home with it out like that?
Maybe the most important question is; Can you tell me how to fix it?
Thanks
Certainly not right. I would fully extend and retract your awning a couple times to see if you can get it to kick into place (hearing your "clunk"). If it stays out, I would tie it up on that end or both ends prior to traveling at highway speeds.
Our Fiamma manual awning does not fully engage on the rear when closed. We travel with this strap in place. There is also a recent thread on this:
There is an adjustment for that.  There should be a description as to how to make that adjustment in your "Oliver Standard Components Manual".
Edited by Tom and Doreen
