ridgwayk Posted December 26, 2015 Share Posted December 26, 2015 Anyone know if we could use the following hitch for sway control? It's called the Equalizer hitch that we had with our airstream. Not sure if it would work with the bull dog hitch. https://www.equalizerhitch.com/pdf/0512 ... hureLR.pdf Thanks ! Happiness is seeing Atlanta in your rearview mirror. :-) Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted December 26, 2015 Moderators Share Posted December 26, 2015 Been down this same road - the bottom line is that it will work, BUT, you will need to trim out parts of the cowling that covers the propane tanks to make room for the brackets that attach to the frame. I choose not to do that. Bill 2017 Ford F150 Lariat 3.5EB FX4 Max Towing 2016 Oliver Elite II - Hull #117 "Twist" Link to comment Share on other sites More sharing options...
trumpetguy Posted December 27, 2015 Share Posted December 27, 2015 Ollies don't sway. I have removed the Anderson hitch and added air bags for balance and weight. No hook up issues...just push a button to inflate/deflate the bags. Current 2007 Airstream Classic Limited 31 2015 Oliver Legacy Elite II (Sold) 2016 Ram 2500 HD 6.7i Cummins turbo diesel Link to comment Share on other sites More sharing options...
routlaw Posted December 30, 2015 Share Posted December 30, 2015 Agreed, they don't sway. Well not enough to make an issue out of it. Our F150 also has electronic sway control when towing and as far as I can tell given some of the harrowing experiences we have had on the road since pick up date I would say it works very well indeed. I assume that most other modern day tow vehicles have similar technologies for sway control while towing. The long and short of it is don't worry about it. You'll be fine without a weight distribution hitch or sway control bars. Ollies don't sway. I have removed the Anderson hitch and added air bags for balance and weight. No hook up issues...just push a button to inflate/deflate the bags. Legacy Elite II #70 Link to comment Share on other sites More sharing options...
ridgwayk Posted December 31, 2015 Author Share Posted December 31, 2015 Thanks for the info on the Equalizer and the sway....That makes perfect sense. I wouldn't cut into the fiberglass either! So....as someone who's had sway control on their Coleman Sunridge popup (tow vehicle was a 4Runner) and then again on a 25FB Airstream (Yukon XL)...I'm pretty conservative when towing. We're seriously considering the Ollie, but I'm hearing recommendations that the Anderson hitch is not really needed???? Thanks. Happiness is seeing Atlanta in your rearview mirror. :-) Link to comment Share on other sites More sharing options...
Maverick Posted December 31, 2015 Share Posted December 31, 2015 Ridgwayk: I used the Equal-I-zer WDH on previous travel trailers and I think it is the best WDH on the market. However is does not work with the Oliver, so I had a Anderson WDH installed when I picked up the trailer on September 2, 2015. I have not experienced any issues with the Anderson; it smooth's out the up's and down's on the road which makes for a improved ride, plus adds a little extra protection when needed. I have been pulling travel trailers all over this country for over 40 years and would not pull any trailer the size of the Oliver without a WDH, but that is my opinion. Horace & Dianne Chesapeake, Virginia 2016 Toyota Tundra Crewmax 4x4 Limited 2015 Oliver Legacy Elite II - Hull # 93 Link to comment Share on other sites More sharing options...
ridgwayk Posted December 31, 2015 Author Share Posted December 31, 2015 Thanks for the input everyone. I think the Anderson sounds like a good purchase if nothing more than insurance and a bit more protection and general piece of mind. Happy New Year to all of you!! Happiness is seeing Atlanta in your rearview mirror. :-) Link to comment Share on other sites More sharing options...
