jd1923 Posted June 5, 2025 Posted June 5, 2025 7 hours ago, Galileo said: OK, we love you guys. Our old 10-year-old hull #113 looks better, pasty white only when cleaned, rarely every washed, let alone waxed, LOL (get a pressure washer)! 🤣 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Galileo Posted June 5, 2025 Posted June 5, 2025 11 hours ago, jd1923 said: OK, we love you guys. Our old 10-year-old hull #113 looks better, pasty white only when cleaned, rarely every washed, let alone waxed, LOL (get a pressure washer)! 🤣 Looking good! Aside from the dirty back end, it looks great. We have an older (much older) sailboat that has been sitting in the Louisiana sun for 25+ years and the deck is very pasty/chalky. The gelcoat has worn completely away in a few places, but when it’s aggressively cleaned it regains a good bit of gloss. No idea how thick (or consistent) the gelcoat is on the Ollie, but I would imagine it could take several years of chalking and cutting before you’d run out of surface that would polish out. I’ve had several pressure washers. Judiciously used, they can be real time-savers. That said, they just plain don’t get ALL the dirt off. You need a sponge or rag or washing mitt to get down to the actual surface - even if you’re not trying to remove tree sap, bugs, or bird droppings. That’s takes good old, US made elbow grease! 2 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Galileo Posted June 5, 2025 Posted June 5, 2025 11 hours ago, Patriot said: Yes, it’s much easier to remove the streaks for sure. When not on the road, I park our Oliver in our “Ollie Hangar” here at home. It has really helped keep it clean and streak free and out of the UV. If you have the property, that’s a great option. Since we’re all but full-time, we have no property. We opted for indoor storage to keep not only the sun and birds, but the millions of mud-home-building insects out of every nook and cranny. Pricey - but worth the cost! 3 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Jason Foster Posted June 12, 2025 Posted June 12, 2025 Two weeks in the rain in south Texas and I am still happy I removed the horrible crap retainer. It streaked some after the rain, but it always does, even with the seal. I use Star Brite's Black Streak remover which is safe for wax, and it takes care of it. Nothing replaces working to make things nice, though. Awning works great and even though water streaks down the side between the trailer and the awning, it doesn't make a mess. I'm glad I removed it. 1 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Galileo Posted June 14, 2025 Posted June 14, 2025 My intent was to try leaving it off, but after seeing how badly the curb side of the trailer streaks, I’m thinking now that I will install the new seal I purchased. The problem - as I see it - is that even with the seal removed, the awning creates a narrow gap that does catch tree debris. These are held here and create the streaks. The street side - in our case with no awning - has nothing to slow down the flow of water or trap debris, so everything washes right off. I was (un) pleasantly surprised to discover that after I removed the seal, cleaned off the whole roof and around the awning brackets, and cleaned and buffed away the streaks - it rained that night - bringing down tree litter - and re-streaked the curb side even worse than it was before! 1 2 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
jd1923 Posted June 16, 2025 Posted June 16, 2025 On 6/14/2025 at 2:34 PM, Galileo said: My intent was to try leaving it off, but after seeing how badly the curb side of the trailer streaks, I’m thinking now that I will install the new seal I purchased. Do that. We have a simple 1" drip edge on the curbside and do not get streaks. Nothing on the streetside, it gets streak. If I was to ever get our Oliver polished and waxed or otherwise coated, I would put new drip edge on BOTH sides. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Teaney Hull 292 Posted November 5, 2025 Posted November 5, 2025 On 7/20/2022 at 12:06 PM, J-Rhett said: I'm in the process of taking mine off now. It has deteriorated badly and I've pulled off about 10" from the rear and there is glue still on the trailer. Looks like I'm going to have a time of it. I will also take off the awning completely as a little wind came up in TN and broke my mid-support plastic on the end of it and bent the opening cover of the awning. Maybe I can fix it with a rubber hammer as it's not too bad, maybe now. Hope I can just by the parts I need. I've spent too much money on other things as of late. We too had a storm yank our awning, the 2017 CareFree one, annd had to shove it in while cranking. Now and we can no longer open it. I even got a new crank and it still won’t pull in the last few inches and will not come out at all. Any one have a solution, short of a new awning? Gary and Anita Teaney and Ranger 2017 Oliver Elite II Hull 292 2018 Nissan Armada Tampa, FL
CRM Posted November 5, 2025 Posted November 5, 2025 16 hours ago, Teaney Hull 292 said: We too had a storm yank our awning, the 2017 CareFree one, annd had to shove it in while cranking. Now and we can no longer open it. I even got a new crank and it still won’t pull in the last few inches and will not come out at all. Any one have a solution, short of a new awning? Gary- it's likely that the support arms got bent or damaged when the wind got a hold of it. You'll probably have to have someone pulling out hard on the awning while someone else cranks it to get it open to see what the damage is. 1 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
