15 minutes ago, Steve Morris said:
Rather than use the web-based mapping tool, I simply found a large US map, and fill in my own states. I use a graphic application on my computer to "fill" each state (in my case one color for "camped in" and another for visited with the Oliver, but didn't camp.) I save a copy of the map with the states filled, then made a 200 pixel wide copy, and paste that into the signature file. To add a state, I simply fill in the new state on the original large file, and save a new 200 pixel wide copy. (I've found that the resolution on the small file is too low to use the "fill" tool there, which is why I do the changes on the large map.)
Here's a start for you. To add Canada, find a similar map, or, start with a blank North America map for both the US and Canada.
Thanks, I will be be adding New Mexico when we get back from that trip end of Oct.👍
I just added the map with the help from my 10 year old grandson, I’m getting to old for this stuff. I’m learning some things 😳,map just has states we camped with the Oliver.  Been to many more . We have been camping for 43 years..Stay safe out there..
2022 Elite I  # 1179  |  2024 Tundra SR5 4x4 Crewmax. 5.5 ft. Bed. 3.31gears 10 spd.trans
1 hour ago, John Dorrer said:
Where can you find the Canadian map?
I linked to a Canada map and Canada/USA that I found on Google Images in the above post. Here are both files:
Blank-outline-map-of-the-United-States-and-Canada.thumb.jpg.33bdede50854fcfca187d9b412ae2b24.jpg
Edited by Steve Morris
Steve - Northern Ohio, USA
Facebook - Instagram
Awesome. Thanks Steve
I actually went back to the original link for the US Map and scrolled down to find the Canadian Map. I entered the Provinces and then copied it and pasted it into my signature. Thanks for the help.
  • 9 months later...
I think I have followed each step, but in the end my old map continues to show. I copied URL but not sure where to past it. I pasted in the box and the URL showed just for a second. My new map showed. I clicked on save. However the old map continues to show.
I followed every step, pasted onto my signature page. See the screen shot. I then scrolled to the bottom and hit save. Still my old map continues to show up.PXL_20250524_121412438.thumb.jpg.1694a90cb8c537b3d2bb9218153cc40f.jpg
John, I think I had a similar experience when I tried to replace my old map. If I remember correctly, I finally deleted the map and logged out and then back in again. Have you tried this?
I'm seeing both the US and Canada on your post -- isn't that what you intended?
my Oliver has camped here
Yep. How do you delete the old US map? I haven't tried that. Let me know how to delete the old one. What's strange is my profile shows the new map, but when I save it and then go to one of my posts the old one is still there.
I will try to do it myself .... and maybe make screenshots of the process. But my cousin and I are heading out in a bit and I have to eat first, so more likely will try to do this tomorrow...
EDIT: to delete the map do the following:
1) go to Profile
2) click ACCOUNT SETTINGS (upper right side of your background photo)
3) on left side of Account Settings page, click on SIGNATURE
4) click on the image / link and DELETE.
Edited by Boudicca908
updated info
1) go to Profile
Thank You
1) go to Profile
Deleted it. However no matter what I do the new map won't  load. I followed each step to the "T". The new map was saved in my profile, appears in my profile, but won't show up after I hit save.
50 minutes ago, John Dorrer said:
The new map
Can you post a photograph of the map you are trying to add?  Now I see Canada but not the US on your signature...
I got it. This was totally my error. I was clicking on the wrong place on my profile. The instructions were clear, paste on signature. Sorry for creating a cluster "F__K"🙃
Edited by John Dorrer
Typo
  • 4 months later...
I must be doing something wrong.  I have tried on my cell phone and on my computer.  I save my map. I copy my URL. I go to my signature page. i CLICK ON EDIT.  I paste the URL.  My new map shows up. I click save.  When I go to one of my old posts the original map is still there.  I thought all  previous posts would reflect the new map.
There is something not happening when I go to edit my signature.
3 hours ago, John Dorrer said:
Totally my error.
Care to share where you went "south"?
The problem was saving the IRL. I'm still not sure exactly what I did to get to work🙃
