Calypso Posted May 5, 2019 Posted May 5, 2019 Going through our factory tour pics we did not see any power or USB outlets on the nightstand. Does anyone know if there is 12 volt access at or close to the nightstand? Bob
Moderators mossemi Posted May 6, 2019 Moderators Posted May 6, 2019 It may be an option, but we have an AC 120v outlet, 12v cigarette lighter receptacle and 2 USB ports on each side of the night stand. Mike Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Moderators topgun2 Posted May 6, 2019 Moderators Posted May 6, 2019 As Mike said - it may be an option or even standard equipment at this point. During our build I had only one "set" (12 volt plus USB ports) put into the nightstand. Bottom line is - either way it certainly can be done either by the factory or if you are a bit "handy" you can fairly easily do it yourself. Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Landrover Posted May 6, 2019 Posted May 6, 2019 If you look at the wiring diagrams for 12v and 110v you should have these plugs at the night stand as standard equipment. Grant 2022 GMC Denali 2500 HD 2019 Elite 11😎
KountryKamper Posted May 6, 2019 Posted May 6, 2019 There is 120 volt, 12 volt and USB on each side of the nightstand as standard. 1 Tom & Cheryl LE II #305 2018 GMC 2500HD SLT Duramax
