Going through our factory tour pics we did not see any power or USB outlets on the nightstand. Does anyone know if there is  12 volt access at or close to the nightstand?
Bob
It may be an option, but we have an AC 120v outlet, 12v cigarette lighter receptacle and 2 USB ports on each side of the night stand.
Mike
As Mike said - it may be an option or even standard equipment at this point.  During our build I had only one "set" (12 volt plus USB ports) put into the nightstand.  Bottom line is - either way it certainly can be done either by the factory or if you are a bit "handy" you can fairly easily do it yourself.
If you look at the wiring diagrams for 12v and 110v you should have these plugs at the night stand as standard equipment.
