I have a 2009-2010 Oliver Legacy Elite trailer Hull #35. Can anyone that has a similar age Oliver tell me what the model number of the Fiamma Awning is. Mine has no markings on it that are still legible. I lost a plastic outer end cap on my last trip to Lake Ouachita and want to make sure I order the right part. Thanks!
Charliep -
Have you looked on your "build sheet" or delivery paperwork? With mine the serial numbers and or model numbers were listed there.
We didn't get build sheets in the early days.we got a folder full of manuals.
We no longer have the original fiamma. But, i think Pete (bugeyedriver) does. You could pm him.
I would also call factory service. They might just have an old end cap somewhere in the boneyard. Ours discolored around year 5. We pulled them off and painted them with Krylon. Worked for another 4 or so. As i recall, replacement was around 50 bucks.
Darn it! Perhaps a call to Sales - they might still have a record.
The awnings on the early (circa 2008) Oliver's were not made by Fiamma (although they look like them.) They were Horizon awnings made by Dometic.   This parts blow up may help.  Also, check here.
The Wonder Egg, hull #14's awning says HORIZON on the outside, the arms are marked FIAMMA, and the housing has a DOMETIC sticker.  Go Figure!
When my end caps became brittle from UV, I ordered new ones from   gowesty.com.  I ordered for the F45i. Here are the part numbers.
Left end cap - part # 04275-01C
Right end cap - part # 04274-01C
Before putting the new end caps on, I painted them with a white Krylon plastic paint, which has UV protection properties.  They have lasted much longer than the originals, at this point. (Although it looks like they will need some TLC when I get home)
