Now that our travel plans have been limited, we are interested in acquiring a protective cover for our new Elite II. Would anyone have a suggestion of manufacturer and model to fit the E2? Thanks.
2019 Chev Colorado Z71 4x4 Duramax 2.8L Turbo-Diesel
2020 LEII Twin Bed Hull #586
Calmark makes a custom fitted cover, they are expensive to the tune of around $900 plus shipping.
topgun2 has one and might chime in on his ownership pros/cons.
Here is the linky...
https://calmarkcovers.com
Edited by Patriot
TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor
North Carolina 🇺🇸
Adco also makes custom RV covers from Sunbrella fabric.  I've owned both over the years and strongly believe that the CalMark covers are better - and slightly more expensive.  The reinforcing webbing that CalMark uses decreases the pressure on the fabric thus makes the cover stronger and longer lasting.  Also, the CalMark has a "draw-string" in the hem at the bottom which allows you to tighten the cover around the bottom without the need for additional rope underneath.
The only real problem with both covers is the weight.  Getting the cover to the top of the Oliver (or any RV for that matter) can be a bit of a challenge - particularly if you try putting the cover on by yourself.  However, I've never really had a problem taking the cover off given the smoothness and shape of the Ollie.
I know that CalMark has the dimensions of the Oliver and, therefore, does not need you to measure yours for them.  I would guess that Adco also has these measurements but do not know this for sure.  If you have any other questions, fire away.
Thanks for the information. As you all said, that is quite a high price. I will have to weigh it against the cost of a permanent carport.
The only thing I dislike about covers, is they are like wrestling with an elephant. Things you need are tall ladders and a wife that feel comfortable on one. My wife is considering the $15,000 wood cover option, so far we don't have a cover as of yet, but she is winning so far.
trainman
