Patriot Posted May 22, 2020 Posted May 22, 2020 (edited) We bought a used 2019 Calmark cover for our new 2020 Oliver LEll. The cover has no visible holes or tears And appears in decent condition and even came with the original patch kit. After unpacking the cover on our driveway we noticed it does have a dusty tan colored stain on the very top. Calmark warns to use ONLY non detergent soap. We sent an email to Calmark asking what specific non detergent soap to use. They are closed due the pandemic but may be monitoring email. Any suggestions on non detergent soap to clean the cover with would be appreciated. We may just try hosing that area off with just water first. We’ll post up if we receive a response from Calmark. Thanks, -Patriot This appears to be a tree sap maybe? Edited May 24, 2020 by Patriot 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Patriot Posted May 23, 2020 Author Posted May 23, 2020 We were able to reach out to Calmark covers and ask how they recommend cleaning the cover. We hope this helps anyone owning a Calmark. Here is there reply- From: "CalMark Cover Co." <info@calmarkcovers.com> Date: May 22, 2020 at 5:39:02 PM EDT Subject: Re: Best cleaners for CalMark covers Thank you for checking with us on the proper way to clean and care for your cover, I have attached some sheets on cleaning the fabric, I also included a stain chart as well. Normally, you can gently hose down your cover to remove any surface dirt. You can use a Dawn dishwashing fluid and a rag or soft bristle brush. Then, gently rinse with water again. It is NEVER safe to put your cover in a regular or industrial washing machine. They can damage the fibers of the fabric and remove items that the fabric was originally treated with, such as those that protect against UV Rays, mold, mildew and the overall water resistance. There is also a company called 303. They make a biodegradable product used to clean Sunbrella. They also make a spray that you can use to retreat your cover for water resistance. It is a good idea to clean, then retreat, about very 1-2 years. For a specific type of stain or spill, please refer to attached chart provided by Glen Raven. DeAnna Martinez Sales/Customer Service CalMark Cover Company (800) 838-7236 3 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Steve-Gwenne Posted May 23, 2020 Posted May 23, 2020 Another CalMark cover question --- can you run the Maxxfan with the cover over the trailer? We run our fan with the bathroom window open 24/7 to keep some air moving around inside. If you are unable to run the fan, how is the air inside the trailer after a period of time? This is not actually an owners question; we are 'to be' owners, amybe. 🙂 Thank you. SGC & GRC Hull 224 [2017] 2017 GMC Sierra HD Crew Cab Diesel
Moderators topgun2 Posted May 23, 2020 Moderators Posted May 23, 2020 sgcausey - While the CalMark cover is not waterproof, it is fairly water repellent. Given that, while it does "breath" I'm sure that the airflow through it is not very good. Therefore, I have never left any vents (MaxAir or bath) open while in storage. However, to control humidity inside the Ollie I have used a combination of a product called "Damp-rid" along with a renewable desiccant (renewed by plugging it into a 110 outlet a couple of times over the winter). I also make sure to use crumpled newspaper in the fridge and leave the fridge and bathroom doors open, and I remove my sleeping mattress but leave the dinette cushions in place. With these precautions I've never had any odors. Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
John E Davies Posted May 24, 2020 Posted May 24, 2020 I haven’t had.a trailer cover in over thirty years, but in your shoes I would go buy a kids plastic wading pool at Walmart, fill it with cold water and a half cup of Dawn, and let the cover soak for a few hours or overnight. Spot treat the worst dirt first. You can agitate it with your hands or by lifting up the cover. https://www.walmart.com/ip/Summer-Waves-59-Plastic-Wading-Kiddie-Pool-Assorted-Colors/629867360 Once you have cleaned it, and rinsed it really well, you need to find a way to let it drain and air dry, say hung over a clean fence. Be really careful to never lay it on a dirty driveway. Rinse the concrete very well or you will just contaminate your clean cover. And never put it on your Ollie if the fiberglass is dirty..... I have never been happy with the concept of a fitted vehicle cover, I had one for a black car and it just worried the heck out of me, I decided that old flat bed sheets laid carefully on top worked better indoors, and were so very easy to wash. Too bad that won’t work on an outdoor trailer.... Good luck. John Davies Spokane WA SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
