Ray and Susan Huff Posted August 30, 2020 Posted August 30, 2020 Can someone with the twin bed optional basement access door tell me the size of the opening? Also, am I correct to assume a potable water hose and pressure regulator come with the trailer? Any other accessories? Thanks Ray and Susan Huff Elite II Twin "Pearl" - Hull#699; delivered December 7, 2020 2013 F350 6.7l diesel Super Duty 4x4 long bed crew cab 1UP-USA Heavy-duty bike rack 2017 Leisure Travel Van Unity Twin Bed (sold)
Moderators topgun2 Posted August 30, 2020 Moderators Posted August 30, 2020 Yes on the water hose and regulator. You are also "given" a sewer hose. In years past there was also a lug wrench. Literally down the street from where you take delivery there is a Tractor Supply - good for getting a better "pin" that has a handle for the Andersen WDH (note the red handled pin on the whale tail in the photo below) - and a WalMart for all those other things that you either forgot or simply "need". Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted August 30, 2020 Posted August 30, 2020 Your Ollie sales rep can provide you with the latest list of items you receive on delivery day. If you TV is a Ford F-350 as indicated in your signature, you won’t need the Andersen WDH set up or the pin. As Bill mentioned other things can be picked up as needed at TS. I think there is a list of items provided here on the forum somewhere. Our sales rep provided this up to date list as we got closer to delivery date. - Patriot 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
ThomB87 Posted August 30, 2020 Posted August 30, 2020 The hatch opening is 13 1/2 inches wide by 7 1/2 inches height in our 2019. Bill Thomas 2019 Elite II Hull # 534 2020 Chevrolet Silverado HD 2500
