Anyone had to replace the shutoff bypass valve ?, looks tight to get to. And no antifreeze pressure to the water lines, is that a issue?
I replaced mine. My bypass used screw connectors so I just unscrewed the whole bypass circuit and made a replacement to match.
It’s the piece on the bottom left here -
Edited by Overland
Is that your newly fabricated replacement plumbing with metal fittings?
Parts of it. All brass fittings and stainless crimps. And also a better quality PEX except for a few bits I reused. I tried as best I could to make it modular so that sections could be pulled out easily to repair. It’s so difficult in places to maneuver a crimper, pipe, arms, etc. inside the hull.
Everything stayed tight though on our recent trip, even with some good bumping around. Feels so much more solid, though it’s definitely an overkill project and one that I’d never have done had it not been one of those ‘if I’m doing this, then I may as well do that’ sort of things.   Nor would I have done it if I’d actually bothered to count all the friggin fittings and crimps ahead of time.
Edited by Overland
I  noticed mine was leaking a bit - under pressure. Not gonna worry about it. Plenty of anti freeze everywhere, the filter is out  of the Truma. Nor sure why I would replace it unless it just really lets loose.
RB
