Can someone kindly post the link to Oliver’s service posting about this jack.  I read it this past winter but can’t recall where it was located, nor can I find it in the Service Bulletins section.
Thanks.
Bob G
I don’t recall an Oliver bulletin about this, but there was a short video, it basically said remove the top and daub some more grease inside. It really needs a little more attention than that. My “grease” was more akin to chilled Play-Doh, and it was contaminated with steel particles from the dry gears:
https://olivertraveltrailers.com/forums/topic/4094-how-to-vip-3000-electric-stabilizer-jack-service/
I do recommend that you buy several new gaskets to have on hand, BEFORE you start, one of mine tore.
And be sure to check the attach bolts at the frame, they do loosen.
Rleog -
THIS may be the post (by JD) that you are referring to.
p.s.  note that a video by Jason in Oliver Service is included in this thread.
