So I am planning on making a cable Like John Davies did to run from my Zamp solar port to my truck bed to run a Iceco Fridge/freezer.  I was under the assumption that the port connects directly to the batteries.  When I went to test for voltage at the port I wasn't getting anything so I looked under the streetwise bed to see how the connections were done.  The pictures below show what I found. The red wire from the port connects to another red wire and the black wire connects to a yellow wire that goes toward the front of the trailer but isn't connected to anything.  Should this yellow wire be connected to the bus bar in the picture?  Is that why I am seeing no voltage because there is no ground?
John and Kim
Yes, that wire should go into an unused socket in the ground bus. Strip off some insulation, somebody just forgot that one, and it was not caught before delivery!!! Check all the other screws, there may be loose ones.
Thanks John.  I was assuming that was the case but this yellow wire is not even stripped at the end.  If it was stripped I would have assumed it came out of the ground bus but the previous year diagrams show a yellow wire for the port going directly to the battery.  I'll give it all another look when I get back to the trailer tomorrow.
John and Kim
I'd agree, by Oliver standards, yours should have been connected.
It seems that Oliver standards are slipping a little bit.  When we took delivery our trailer was filthy.  If I purchased a $75000 car it would be shining when I drove it off the lot.  After I got to Davie Crockett I noticed the bumper on the door was loose.  It was attached with a single screw through the thin sheet metal door.  The latch to hold the door open was through bolted with an aluminum backer plate.  Why the bumper wasn't done in a similar way makes no sense.  I rectified it when I got home.
John and Kim
As with a bunch of things - "the devil is in the details".  A really nice job of connecting all those ground wires to the bus bar spoiled by not connecting one more.  I suspect that the Zamp solar port was installed later.  Certainly this is no excuse for missing the Zamp connection.
If you haven't already done so - please forward an email to Jason Essary with the pictures above.  Both Production and Service have quality control checklists that this issue should be added to.
I am a big fan of Klein tools 😁. I am glad you are up and running, is there a fuse in the positive line? Mine did not have one, it should be “about” 10 amps, my Furrion port is rated at that. I am not sure what the Zamp one requires.
Something else you may want to do is replace the Zamp port screws with pan head #6-1/2" stainless steel screws. Mine rusted and were starting to leave orange rust stains on the hull.
Jerry & Kathy
2019 LEII Standard #539 + 2019 Tundra Limited 4X4
That’s a good point John,  I will have to check for a fuse.  I’ll replace the screws also.  😁
John and Kim
