Guest Posted January 12, 2022 Posted January 12, 2022 Has anyone here converted the side export for portable solar panels from an SAE to an MC4. We have a portable power station that uses MC4 and would rather just have one plug type. Since there is some confusion with the SAE plugs and some questions concerning their reliability, we are looking at the possibility of changing that side port to MC4. Thanks, Kirk
VBistro Posted January 13, 2022 Posted January 13, 2022 I haven't yet, but would be interested in replies. We have a 200W Renogy suitcase + controller with converting/polarity reversing adapters (I haven't determined yet whether I need the polarity adapter). It would be nice not to have to use those and just plug straight into an MC4 outlet. MaryBeth Boulder, CO 2022 Elite II #953 TV: 2021 Ford Expedition Max Platinum, Max Tow Package
Moderators SeaDawg Posted January 13, 2022 Moderators Posted January 13, 2022 I'm kind of confused. I don't think I've ever seen a portable panel with an mc4 male or female end to plug onto a port. Mc4 connectors aren't easy to separate, in my experience, and are not made for quick connect like some other types. We have a special little plastic tool to disconnect our fixed panel mc4 connectors, which are semi "permanent " connections. Many suitcase solar come with alligator clips. Zamp uses sae, wired reverse of standard. Some brands come with a few varieties of connectors. I've not seen quick connect mc4 in portable solar, but maybe there's something new out there. Edit to add: I looked around, and found these quick connect mc4 connector pairs from a Canadian company. Is this what yours look like? http://azimuthsolarproducts.com/product/mc4-connectors/ 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
bhncb Posted January 13, 2022 Posted January 13, 2022 MC4 connectors are typically used to interconnect PV panels and an unregulated charge controller input. The ZAMP proprietary SAE connects directly to the battery bank. If it were "converted" to MC4, it would be possible to connect the PV array directly to the batteries without a controller. The unregulated higher voltage of the array would "fry" the batteries. 1
Moderators SeaDawg Posted January 13, 2022 Moderators Posted January 13, 2022 On 1/12/2022 at 10:17 PM, Kirk Peterson said: Has anyone here converted the side export for portable solar panels from an SAE to an MC4. We have a portable power station that uses MC4 and would rather just have one plug type. Since there is some confusion with the SAE plugs and some questions concerning their reliability, we are looking at the possibility of changing that side port to MC4. Thanks, Kirk Expand Many power stations have an internal integrated controller, so your panel may not/probably doesn't have a controller. You'd need to add one, to safely use it with the Ollie, as the solar port does not run through the on-board controller for the fixed panels. The port connects through just a fused line, going straight to the batteries. X2 @bhncb 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Guest Posted January 13, 2022 Posted January 13, 2022 I have considered one or two of the Bluetti PV200 200 watt panels, they come with an MC4 connection and weight 16 pounds. I was planning on a solar controller, either inside the battery storage area if there is room and it wouldn't be too hard. Or, if possible, maybe a the controller between the panels and the Ollie side port, possibly in a pelican box or something similar. At least that's what I am pondering.
John E Davies Posted January 13, 2022 Posted January 13, 2022 On 1/13/2022 at 3:01 AM, Kirk Peterson said: Or, if possible, maybe a the controller between the panels and the Ollie side port, possibly in a pelican box or something similar. Expand Very possible, and works quite well. https://olivertraveltrailers.com/forums/topic/5478-how-to-remote-mount-the-controller-of-a-suitcase-solar-panel-not-inside-the-trailer/ John Davies Spokane WA 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Guest Posted January 13, 2022 Posted January 13, 2022 On 1/13/2022 at 3:34 AM, John E Davies said: Very possible, and works quite well. Expand Thanks John! That looks great! 👍
VBistro Posted January 13, 2022 Posted January 13, 2022 The Renogy suitcase I have has a controller and comes with cabling terminating in an MC4 connector. It has a set of alligator clips that couple via MC4, so they aren't hardwired. This allows me to use an MC4-to-SAE adapter to connect to the Zamp Solarport, but I would like to minimize the number of adapters. Not a deal-breaker as-is, but not as clean as I would like either. MaryBeth Boulder, CO 2022 Elite II #953 TV: 2021 Ford Expedition Max Platinum, Max Tow Package
