Hi there.
I'm interested in replacing some or all of our interior LEDs with warmer lights.  I don't know what the factory installed lights are, but would prefer something in the 3000K range.  The bright light is great, but there are a lot of bulbs, and my eyes (and brain) need a break.
I have a note out to support at Oliver, and they are checking with manufacturing for part numbers, but I'm curious if anyone here has replaced their bulbs.
mb
MaryBeth
Boulder, CO
2022 Elite II #953
I've replaced all the bulbs in our original fixtures (2008). But, i think many of your fixtures have integrated leds, unlike mine. Good news, leds have dropped so much, fixtures now are more reasonable than led bulbs, back then.
I left brighter light over the cooktop and one side of the small dinette, and the one light each in our closet and bath, for better vision.  Something you may wish to consider, or not, but I find a colder light helps me see doing paperwork, and detail work, and cooking. We don't usually have any of these on with warmer lights, as that kind of messes with my brain...
These lights should be very close to a direct replacement but would require cutting the old wires and splicing these in.  There are two version's, screw mount and spring mount.  If you have the correct size hole, the spring mounted lights are very easy to install, but my lights are screw mounted.  I am not sure if ITC is the brand of interior lights Oliver is using or not, but my porch lights were/are ITC brand.
https://itcshopnow.com/collections/rv-products
Edited by mossemi
typo
Or -
install a dimmer.
