John Dehne Posted July 13, 2022 Posted July 13, 2022 We would like to add a LED dimmer to our Girard awning on our 2021 Hull 901. Looks like it would have to be mounted and wired next to the wind sensor. Have any of you done this? Thanks in advance. John & Chris Dehne Manchester, MD. 2021 Elite II twin Hull# 901 “Fiberbeergrass” 2021 Ram 2500 Cummins 4x4 Life is good!
Sak Posted July 13, 2022 Posted July 13, 2022 I have not done that but, FWIW, I plan to add dimmer for all outdoor LED lights by replacing the light switch with something like this inline dimmer. I hope that I can just replace a switch using the simplified hookup below. What I am not sure is that the LED lights Oliver using are dimmable or not. I also don't know how I would retrofit the dimmer into the control panel. 2021 Oliver Legacy Elite II - Hull #854 2021 Ford Expedition Platinum
Sak Posted July 13, 2022 Posted July 13, 2022 2 hours ago, John Dehne said: Have any of you done this? oh, forgot to mention, looks like someone mentioned here that should be doable. 1 2021 Oliver Legacy Elite II - Hull #854 2021 Ford Expedition Platinum
VBistro Posted July 14, 2022 Posted July 14, 2022 10 hours ago, sak said: I have not done that but, FWIW, I plan to add dimmer for all outdoor LED lights by replacing the light switch with something like this inline dimmer. I hope that I can just replace a switch using the simplified hookup below. What I am not sure is that the LED lights Oliver using are dimmable or not. I also don't know how I would retrofit the dimmer into the control panel. I wanted to put dimmers on the interior lights, but heard back from Oliver that they are not dimmable. Bummer. Let me know what you learn about the outdoor bulbs! 1 MaryBeth Boulder, CO 2022 Elite II #953 TV: 2021 Ford Expedition Max Platinum, Max Tow Package
Jps190 Posted July 14, 2022 Posted July 14, 2022 This stuff is great for the outdoor lights. Makes them dimmer and less harsh. John Lamin-x One 4 inch x 8 inch... https://www.amazon.com/dp/B00CXWPO72?ref=ppx_pop_mob_ap_share 1 John and Kim 2021 GMC Sierra 2500 AT4 6.6L Duramax 11350 GVWR 3048lb Payload 2021 Oliver Elite II. Hull #887. 600 Watt Solar Mod
