Galway Girl Posted May 10, 2023 Posted May 10, 2023 Here's the link to the load PSE/Load tire inflation chart for those Michelin Agilis Cross Climates https://tirepressure.com/lt225-75r16-tire-pressure Agilis Loading Table: The Agilis has a bit higher payloads in the table than the original Michelin LTX M/S that came on my 2019...so they could be a good replacement. Thanks for your posts. Craig 3 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com
routlaw Posted May 11, 2023 Posted May 11, 2023 2 hours ago, Wayfinder said: Well, here are the Michelin Agilis CrossClimate tires. They look like tires. 😂 No shine on them yet. And I lost my metal stems. Darn it. They were out. These are longer too. I don't like it. You will be ok without the metal valve stems unless you want to inflate to max PSI of 80, for pressures in the 40's-50's those rubber should be fine. Agreed though with longer rubber ones they tend to flex too much. 1 Legacy Elite II #70
Wayfinder Posted May 11, 2023 Posted May 11, 2023 1 hour ago, Galway Girl said: Here's the link to the load PSE/Load tire inflation chart for those Michelin Agilis Cross Climates https://tirepressure.com/lt225-75r16-tire-pressure Agilis Loading Table: The Agilis has a bit higher payloads in the table than the original Michelin LTX M/S that came on my 2019...so they could be a good replacement. Thanks for your posts. Craig Thanks. I also posted the entire lineup of these tires a few posts back in this thread. I had the tires inflated to 50 lbs. But even that seems high for these tires and my Oliver. https://olivertraveltrailers.com/forums/applications/core/interface/file/attachment.php?id=26016&key=7584a7c5c8aa611b54b4492d5c7eddeb 2 Chris 2016 Legacy Elite II o--o Hull #110 o--o Wayfinder o--o Twin Bed o--o 2020 RAM 1500 Limited 5.7L Augusta, Georgia
Wayfinder Posted May 11, 2023 Posted May 11, 2023 7 minutes ago, routlaw said: You will be ok without the metal valve stems unless you want to inflate to max PSI of 80, for pressures in the 40's-50's those rubber should be fine. Agreed though with longer rubber ones they tend to flex too much. My tire shop did say these stems are rated for the 90 PSI Michelins. But I'm not an expert in stems... and will never be close to 90 PSI on an Oliver. Chris 2016 Legacy Elite II o--o Hull #110 o--o Wayfinder o--o Twin Bed o--o 2020 RAM 1500 Limited 5.7L Augusta, Georgia
MAX Burner Posted May 11, 2023 Posted May 11, 2023 In NM, the State DOT officers will issue citations to those traveling with E rated tires at pressures above 75 PSI without brass valve stems. 1 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
