Patriot Posted April 11, 2023 Posted April 11, 2023 To Oliver Owners considering the 13500 BTU Truma Aventa retrofit. In the last few weeks, I have been working with Oliver Service on incorporating an optional Honeywell digital thermostat to run the Dometic furnace. This optional thermostat will replace the Dometic mechanical thermostat that Oliver has been installing. I learned good news today from Service Manager Jason Essary that my suggestion to use the Honeywell digital thermostat was tested and approved by Oliver engineers. The Honeywell digital thermostat will be offered as an option for owners having the Truma Aventa retrofit done. Optional Honeywell digital thermostat -https://www.amazon.com/dp/B00H6ARNXO?psc=1&ref=ppx_yo2ov_dt_b_product_details We will have the Honeywell thermostat installed in May when we have our Truma Aventa retrofit install completed. For any technical questions please contact Oliver Service @ 1-888-526-3978 Happy Camping! Patriot🇺🇸 8 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
John E Davies Posted April 11, 2023 Posted April 11, 2023 This has been working great for me for three years. Emerson 1E78-140 Non-Programmable Heat Only Thermostat for Single-Stage Systems Pardon my language, but the mechanic unit is unreliable cr@p with an excessively wide deadband. John Davies Spokane WA 2 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
SteveCr Posted April 12, 2023 Posted April 12, 2023 2021 LE2 For my Aventa installation, I provided the Truma service center with the Emerson thermostat. However, Truma recommended that we re-use the existing Dometic thermostat. (they added a resistor or something to the ceiling box) The Dometic furnace works fine and we still have the original OEM Dometic thermostat "look" and thermostat power source. Steve 1 7
Moderators mossemi Posted April 15, 2023 Moderators Posted April 15, 2023 On 4/11/2023 at 7:42 PM, John E Davies said: This has been working great for me for three years. Emerson 1E78-140 Non-Programmable Heat Only Thermostat for Single-Stage Systems Pardon my language, but the mechanic unit is unreliable cr@p with an excessively wide deadband. John Davies Spokane WA Did you have separate thermostats for heat and air with your OEM Atwood air conditioner? Mossey 3 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Patriot Posted May 6, 2023 Author Posted May 6, 2023 On 4/14/2023 at 10:45 PM, mossemi said: Did you have separate thermostats for heat and air with your OEM Atwood air conditioner? Mossey Great question for @John E Davies 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
John E Davies Posted May 6, 2023 Posted May 6, 2023 On 4/14/2023 at 7:45 PM, mossemi said: Did you have separate thermostats for heat and air with your OEM Atwood air conditioner? Mossey Air Command has a built in thermostat/ control panel plus a small remote for changing modes and temp. It can’t easily be set up with a remote thermostat, to the best of my knowledge, but I never pursued that idea. John Davies Spokane WA 3 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Patriot Posted June 2, 2023 Author Posted June 2, 2023 I meant to provide an update on this sooner. This digital Tstat works great running the Dometic furnace. And honestly it just looks so much nicer that the Dometic mechanical Tstat. https://www.amazon.com/dp/B00H6ARNXO?psc=1&ref=ppx_yo2ov_dt_b_product_details Patriot🇺🇸 3 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
