HDRider Posted August 12, 2023 Posted August 12, 2023 Am I correct thinking one cannot set the AC fan to only run when the compressor is running, like a home unit? Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
rich.dev Posted August 12, 2023 Posted August 12, 2023 Unfortunately you're correct! 1 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Steve Morris Posted August 13, 2023 Posted August 13, 2023 23 hours ago, rich.dev said: Unfortunately you're correct! Or, fortunately, for those of us who need some white noise to block out loud snorers. 😂 4 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
HDRider Posted August 13, 2023 Author Posted August 13, 2023 2 minutes ago, Steve Morris said: Or, fortunately, for those of us who need some white noise to block out loud snorers. 😂 That would be the snorer option. I just thought it was odd that the fan could not, or would not match the compressor. 1 Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
rich.dev Posted August 13, 2023 Posted August 13, 2023 3 hours ago, Steve Morris said: Or, fortunately, for those of us who need some white noise to block out loud snorers. 😂 Haha very true and I feel your pain, I have to sleep with earbuds because of “a” loud snorer…..and it’s not me!😜 2 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Ollie-Haus Posted August 22, 2023 Posted August 22, 2023 This is a topic that is discussed on multiple forums and also YouTube regarding the inability to control humidity with RV AC units that run the fan continually. Unfortunately the design principal of having the temperature control sensor mounted in the plenum air stream for the purpose of cycling the compressor relegates the owner to a life of cycling humidity levels in exchange for constant air circulation. I know it would likely add considerable cost to the AC system but wouldn't it be nice of they would design the units with a variable speed fan that ramps up and down to control temperatures in the cabin and thus allow the compressor to run longer and eliminate the short on/off cycles that result in humidity spikes. 4 What's today?............. the most frequently asked question as a retiree 🙄 Chris and Stacie Neuhaus and Cohen the fearless Border Terrier, Greenfield, Indiana 2021 Ford F350 7.3L Tremor (Redzilla) LE2 #1373 - Ordered 10/21/22 - Delivered 05/10/23
Moderators SeaDawg Posted August 22, 2023 Moderators Posted August 22, 2023 17 hours ago, Ollie-Haus said: This is a topic that is discussed on multiple forums and also YouTube regarding the inability to control humidity with RV AC units that run the fan continually. Unfortunately the design principal of having the temperature control sensor mounted in the plenum air stream for the purpose of cycling the compressor relegates the owner to a life of cycling humidity levels in exchange for constant air circulation. I know it would likely add considerable cost to the AC system but wouldn't it be nice of they would design the units with a variable speed fan that ramps up and down to control temperatures in the cabin and thus allow the compressor to run longer and eliminate the short on/off cycles that result in humidity spikes. Many European and Australian sold units use a variable speed compressor. Eventually, we'll get it here. 3 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
