dewdev Posted September 30, 2023 Posted September 30, 2023 While out this past week camping on the last day, the rotary control switch accidently got set to the Clean setting. Since I had just decalcified (cleaned) the unit last month, I tried to Interrupt the decalcification mode using the AquaGo owners manual. I followed the directions, but the control in the Ollie is still blinking its read light almost every second. I let it run over night thinking it would reset itself after 3 hourss (time it takes in the decalcification mode). If anyone has had this happen, how did you reset the unit? 2018 Oliver Elite II, Twin Bed, Hull #354, new Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
Moderators SeaDawg Posted October 1, 2023 Moderators Posted October 1, 2023 @dewdev, I don't have a Truma, but I've seen this discussed here a few times. Try this? 1 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
dewdev Posted October 1, 2023 Author Posted October 1, 2023 Thanks SeaDawg. The ditection worked like a charm. 3 2018 Oliver Elite II, Twin Bed, Hull #354, new Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
Moderators SeaDawg Posted October 2, 2023 Moderators Posted October 2, 2023 Awesome that you are back in business. We'll thank @Dave and Kimberly, and @Frank C. I just did a search. Glad it worked for you. Happy to help, in my very small way. Enjoy your time in the canadian maritimes, and Maine.. Wish we were there, too! Such a beautiful place! 1 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Moderators SeaDawg Posted October 3, 2023 Moderators Posted October 3, 2023 I hope that other Truma owners will see this, and download the instructions, honestly. From what I've gathered, it's not in the manual, but should be. An easy, and honest, mistake, easily corrected. We have a different brand instantaneous water heater (girard). When/if it fails, we'll likely go back to a standard 6 gallon suburban or atwood, I think, as we mostly live without hookups, so endless hot water is pretty meaningless, for us. We love the easy winterizing, and losing 50 pounds of weight, but a standard 6 gallon serves our limited needs just fine. We know, as we've had both. 1 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Moderators Mike and Carol Posted October 3, 2023 Moderators Posted October 3, 2023 9 hours ago, SeaDawg said: We have a different brand instantaneous water heater (girard). When/if it fails, we'll likely go back to a standard 6 gallon suburban or atwood, I think, as we mostly live without hookups, so endless hot water is pretty meaningless, for us. We love the easy winterizing, and losing 50 pounds of weight, but a standard 6 gallon serves our limited needs just fine. We know, as we've had both. Tank = simple and reliable. 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
dewdev Posted October 6, 2023 Author Posted October 6, 2023 SeaDawg. You are correct those direction were not in the manual. Thanks to your search and posting, I printed the directions on my printer and it is now in my o&M manual. 2 2018 Oliver Elite II, Twin Bed, Hull #354, new Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
