We are into our second month with our new to us 2021 LE1, hull 731. So far, wonderful!  And, as you all would know, we are learning fast how to be at home in our Oliver.
On the way into our campsite last night, a Hipcamp site north of Chattanooga, we had 100 yards of rough terrain and our 2 1/2 gallon water storage tank tipped over on the floor under the front dinette. About 11/2 gallons of water disappeared through the floor. I suspect it is in the basement somewhere.
Will it drain through? Should I worry about that?
We are off to a fast day with family in the region and I won’t be able to attend to it till later tonight if I need to. I’d be glad for any advice.
Geoff
Geoff and Becca Chapman * Pittsburgh
Legacy Elite 1 Hull #731 * TV 2024 Ford Ranger Turbo 2.7L Ecoboost V6
There are "scupper" holes in the very bottom of your Oliver which should allow "most" of this water to drain out.
However, if I were you I'd make sure to prop open the "hatches" under your beds and dinette area in order to allow for more air flow therefore drying this area out even faster.
Bill,
I know once water gets into the "inside bottom" it runs out the scupper holes.
But where does it drain to get into that 'inside bottom area", just not seeing it.
We had water on the floor a few times, but for us it was "ALL TOWELLS ON DECK"...
Can water (or maple syrup) get from the floor to the "inside bottom area" from under the refrigerator?
Bryan
My Visited North America Map
@topgun2 I am running the furnace for 30 minutes with hatches open prior to leaving for the day, and will prop open the hatches as well. Glad to know there are drainage holes down there somewhere. I knew there were weep holes to drain any moisture that got in between the hulls, but wasn’t sure about the basement itself. Thanks for the quick help.
Geoff
The "basement" is comprised of the area between the inner and outer hulls at the bottom of the trailer.  Although there are scupper holes for drainage, there are also lots of places where water could pool, in between and under plumbing lines, duct runs, etc.  If you can, I would also place fans in the open hatches for several hours to accelerate evaporation.
Bryon -
Well -
While the scupper holes will allow "running water" (perhaps read that to mean "a fair amount of water") to drain, there are still a number of places inside the hulls that will catch the water.  Certainly moving the Ollie up and down (front to back) and side to side such as when you are traveling down the road, will help "release" this water from places where the water can catch or collect.  For what water is left over, the scupper holes provide for air movement between the hulls.  The greater the air movement - the faster the water will evaporate.  Indeed, this is one of the main purposes of these scupper holes - to help remove condensation (water) from between the hulls.
p.s.  Maple syrup is probably another story give its viscosity and residual it would leave after it evaporates.  Read the thread about the leaking sewer hoses and cleaning  what was left over after the leak.
Interesting question -
As we all know - our hulls are made in a fashion similar to a boat.  As such, there are limited places that something like water can run from the inner bottom shell down into the outer bottom shell.  However, there certainly are places where this can happen as can be seen in the pics below.  But, certainly a hole in the shell can be easily seen in the one picture and it just so happens this hole is located under the fridge where I assume the propane and electric lines are run.  Note that this picture is looking from the outside into the area under the kitchen sink.  Water can also get between the shells in places like where the entrance door is located.
I've also included a picture of the bottom outside shell in order to see all those places where water just might collect.
For those unfamiliar with "Scupper holes" on the Oliver, they can be seen by looking under any Oliver while looking for stainless steel cups or cones that open towards the rear of the Oliver.  These pieces actually create a "venturi effect" while driving down the road which draws air out from between the inner and outer shells thus helping dry any moisture that may be in between the shells.
Oh, yes. We have a maple syrup story, but it was in our kitchen instead of the Oliver. A mess that keeps on giving!
Geoff, et. al.,
This is something I started doing after loosing a couple of 2 liter bottles of water that dislodged in a bundle of 4 and started to roll around on the floor and slide into the gentle rounded corners on the inside of the trailer (and still rupture and leak...) as we were merrily rolling along through the NWT & YT this last summer.
I got a couple of milk crates and put them in the Dinette footwell, behind the table support tube on the street side of the dinette.  They insert best by removing the cushions and sliding them in empty from the top.  once in, they self adjust so they are both held in the area by the table center pole.
We now keep (4) large bottles of water in one, and maybe some other soda/water bottles/cans in the other side.  We have not had any issues since I decided to do this.
After reading the "LP/CO Detector" section of our manual about placing something in front of the unit that may impede the ability to function as it does, the milk crates should not be a problem.  Read the section of the product manual which addresses what liquids that you should not store next to the "LP/CO Detector".
B~Out
@SNY SD UP That would have prevented my spill. Great solution! On my  LE1 I have the furnace intake vents down there which need free flow, but some kind of container should work. Thx!  For now my aux water tank will be traveling on the shower floor, strapped to the vanity
Geoff
Oh, this was a re-active project, not a pro-active one...
We have a LE II, I am not familiar with the foot well on an LE I.
Would your aux water tank fit in the foot well, and could you then put a bungee around the aux water tank and the post?  keeping it near the post and not blocking air returns?
B~Out,
Reactive project, indeed!  A bungee cord around the dinette post would work! Thx
Geoff
