HDRider Posted January 6, 2024 Posted January 6, 2024 Can someone tell me where the 12v tank heaters are discussed in the manuals? I can't find it.  Thanks Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
Steph and Dud B Posted January 6, 2024 Posted January 6, 2024 I wasn't aware the 2023 models have them. Do they? Our 2022 doesn't. Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Moderators topgun2 Posted January 6, 2024 Moderators Posted January 6, 2024 1 hour ago, HDRider said: Can someone tell me where the 12v tank heaters are discussed in the manuals? I can't find it. As far as I know - there was only one Oliver ever produced that came from the factory with dedicated tank heaters. This was way back in the custom order days (even prior to my hull #117) and was for an Ollie that was to be used during the winter in northern PA and similar locations. Other than that, the tanks are located between the hulls of the Oliver and are "heated" by the radiant heat mainly coming off the hoses that come from the furnace to the various outlets located in the interior of the Oliver - i.e. these flexible hoses are not insulated and therefore give off heat in the area between the hulls. Hope this helps! Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
rich.dev Posted January 6, 2024 Posted January 6, 2024 1 hour ago, HDRider said:  Can someone tell me where the 12v tank heaters are discussed in the manuals? I can't find it.  My LEII hull#1386 doesnât have tank heaters! Pretty sure only some older Ollies have tank heaters, back in the day when Oliver still entertained modification request from owners. 2 **Soldđ** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
HDRider Posted January 6, 2024 Author Posted January 6, 2024 I guess that explains why I can't find them in the manuals. Â I thought the Ollie had tank heaters Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II -Â Twin Bed -Â Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
Moderators topgun2 Posted January 6, 2024 Moderators Posted January 6, 2024 Yep - that 'splains" it.đ 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Ronbrink Posted January 7, 2024 Posted January 7, 2024 18 hours ago, HDRider said: Can someone tell me where the 12v tank heaters are discussed in the manuals? I can't find it.  Thanks Being that Olivers are âfour seasonâ RVs, guess the thought was that tank heaters werenât really necessary! However, some owners âbeg to differâ and addressed their concerns to enhance heat in the hatch areas by various means; more-so to protect waterlines, but the tanks would benefit, as well. The most innovative approach Iâve seen was modification of the existing ducting, whereby holes and/or duct diversions are strategically placed to direct furnace heat, as necessary, to more vulnerable areas. Here are a few pics âborrowedâ from a forum post, full credit to that individual. Do a forum âSearchâ on the matter.  1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2â receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
rich.dev Posted January 7, 2024 Posted January 7, 2024 51 minutes ago, Ronbrink said: Do a forum âSearchâ on the matter. for those who havenât seen the posts referenced by @Ronbrink, here you go!đ  1 **Soldđ** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
