HDRider Posted January 6 Share Posted January 6 Can someone tell me where the 12v tank heaters are discussed in the manuals? I can't find it. Thanks Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4 Link to comment Share on other sites More sharing options...
Steph and Dud B Posted January 6 Share Posted January 6 I wasn't aware the 2023 models have them. Do they? Our 2022 doesn't. Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999: Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted January 6 Moderators Share Posted January 6 1 hour ago, HDRider said: Can someone tell me where the 12v tank heaters are discussed in the manuals? I can't find it. As far as I know - there was only one Oliver ever produced that came from the factory with dedicated tank heaters. This was way back in the custom order days (even prior to my hull #117) and was for an Ollie that was to be used during the winter in northern PA and similar locations. Other than that, the tanks are located between the hulls of the Oliver and are "heated" by the radiant heat mainly coming off the hoses that come from the furnace to the various outlets located in the interior of the Oliver - i.e. these flexible hoses are not insulated and therefore give off heat in the area between the hulls. Hope this helps! Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC Link to comment Share on other sites More sharing options...
rich.dev Posted January 6 Share Posted January 6 1 hour ago, HDRider said: Can someone tell me where the 12v tank heaters are discussed in the manuals? I can't find it. My LEII hull#1386 doesn’t have tank heaters! Pretty sure only some older Ollies have tank heaters, back in the day when Oliver still entertained modification request from owners. 2 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison Link to comment Share on other sites More sharing options...
HDRider Posted January 6 Author Share Posted January 6 I guess that explains why I can't find them in the manuals. I thought the Ollie had tank heaters Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4 Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted January 6 Moderators Share Posted January 6 Yep - that 'splains" it.😇 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC Link to comment Share on other sites More sharing options...
Ronbrink Posted January 7 Share Posted January 7 18 hours ago, HDRider said: Can someone tell me where the 12v tank heaters are discussed in the manuals? I can't find it. Thanks Being that Olivers are ‘four season’ RVs, guess the thought was that tank heaters weren’t really necessary! However, some owners ‘beg to differ’ and addressed their concerns to enhance heat in the hatch areas by various means; more-so to protect waterlines, but the tanks would benefit, as well. The most innovative approach I’ve seen was modification of the existing ducting, whereby holes and/or duct diversions are strategically placed to direct furnace heat, as necessary, to more vulnerable areas. Here are a few pics ‘borrowed’ from a forum post, full credit to that individual. Do a forum ‘Search’ on the matter. 1 2020 OLEll, Twin, 579 No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, Hughes Autoformer, dual Lagun tables, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, Dreiha Atmos 4.4 a/c upgrade. 2012 Silverado 1500 4x4 A.R.E. truck bed cover/BedRug bed liner, 200W solar array/Victron SmartSolar MPPT 75/15 and 100Ah potable power station, Rancho QuickLIFT front suspension strut/coil spring upgrade, Advanced Technology vented/slotted disc brake rotor upgrade, Air Lift LoadLifter 5000 Air Suspension/wireless remote controller, Mechman 320A High Output alternator/upsize cables. Link to comment Share on other sites More sharing options...
rich.dev Posted January 7 Share Posted January 7 51 minutes ago, Ronbrink said: Do a forum ‘Search’ on the matter. for those who haven’t seen the posts referenced by @Ronbrink, here you go!😊 1 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison Link to comment Share on other sites More sharing options...
