Moderators Mike and Carol Posted January 19, 2024 Author Moderators Posted January 19, 2024 I’ve never had any odd temperature readings on any of the four tires on my TST TPMS. I’ll be checking wheel temperature now too…. 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
jd1923 Posted January 22, 2024 Posted January 22, 2024 On 1/18/2024 at 9:18 AM, topgun2 said: Another possible reason for that tire going bad when the other three (bought at the same time) look fine - that tire was defective in the first place... I agree with Bill, given you checked most everything else. @Mike and Carol you have a new tire now, so all is good for many miles, long after you return home. Whatever you do, please do not take the bad advice given to raise your tire pressure! Always maintain tire pressure based on trailer and TV axle weights and tire manufacturer load tables. This is a matter of physics vs. opinion. 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators Mike and Carol Posted January 22, 2024 Author Moderators Posted January 22, 2024 8 hours ago, jd1923 said: Whatever you do, please do not take the bad advice given to raise your tire pressure! Always maintain tire pressure based on trailer and TV axle weights and tire manufacturer load tables. This is a matter of physics vs. opinion. Discount Tire put 75psi in the new tire, because that’s what their policy is. I just winked at the guy and corrected it when I got home. 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Moderators topgun2 Posted January 22, 2024 Moderators Posted January 22, 2024 1 hour ago, Mike and Carol said: Discount Tire put 75psi in the new tire, because that’s what their policy is. Interesting: When I had my new Cooper's installed at Discount Tire, they asked me what psi I'd like to have. Local policy perhaps? Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Ronbrink Posted January 22, 2024 Posted January 22, 2024 2 hours ago, Mike and Carol said: Discount Tire put 75psi in the new tire, because that’s what their policy is. I just winked at the guy and corrected it when I got home. I had DT install metal valve stems on all wheels last summer on a return trip from West Texas, had two rubber stem failures (with mounted TPMS devices) likely due to extreme heat at the time (110°+). Upon leaving, I went directly to a nearby Walmart and deflated the tires to 55 psi. 58 minutes ago, topgun2 said: Interesting: When I had my new Cooper's installed at Discount Tire, they asked me what psi I'd like to have. Local policy perhaps? Bill That would be my guess. 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
jd1923 Posted January 22, 2024 Posted January 22, 2024 2 hours ago, topgun2 said: When I had my new Cooper's installed at Discount Tire, they asked me what psi I'd like to have. Local policy perhaps? Bill Some associates enforce company policy, and some have a better understanding of Total Customer Satisfaction! 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators Mike and Carol Posted January 23, 2024 Author Moderators Posted January 23, 2024 When I had the Coopers installed a few years ago, at the same DT, they filled to my specifications. Probably an individual issue. 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
