Legacy Elite Small Travel Trailer
2026 Legacy Elite is Fully Booked
All available production slots for the 2026 Legacy Elite have been reserved.
For now you can check out the Legacy Elite II model.
Small Camper, Big Deal.
Discover the Oliver Legacy Elite, a premium small compact camper for easy towing and year-round adventures. This 18'5" small travel trailer has an insulated double-hulled fiberglass shell for durability and four-season comfort. Inside you will find convertible seating/sleeping area, kitchen with a flush mount induction stovetop and refrigerator, bathroom with toilet and shower. Explore features and options below for your ideal small camper.
Specifications
Spacious Interior in a Compact Travel Trailer
The Legacy Elite is compact at 18'5" length and 6'6" width, maximizing space and comfort. Inside this trailer you will find convertible dinette, lounging, and sleeping areas.
Side Dinette Converts into a 71" x 23" Bed
Standard Features
Legacy Elite stands out with top-of-the-line features and components.
- Hull Features
- Full Custom Molded Interior and Exterior Insulated Shells Standard
- Transportation Grade Gel-Coat with UV Protectants Standard
- Custom Molded LP Cover Standard
- Custom Molded Spare Tire Cover Standard
- Plumbing, Holding Tanks and Drain Pipes enclosed between shells with heat to diminish freezing Standard
- 32 Gal. Design Capacity Fresh Water Tank Standard
- 32 Gal. Design Capacity Grey Water Tank Standard
- 15 Gal. Design Capacity Black Water Tank with pressure flushing system for the Tank Standard
- Chassis Features
- Heavy Duty Anode Protected Aircraft Grade Aluminum Frame Standard
- Dual Gas Shocks on Single 5000 Lbs. Dexter Leaf Spring "Nev-R-Lube" Axle with โNev-R-Adjustโ 12โณ Electric Brakes for Exceptional Control and Braking (Now with Bronze Bushings & Grease Zerks) Standard
- Premium Aluminum Rims with 10-ply Tires Standard
- Full Size Spare Tire with Aluminum Wheel Rim Standard
- 7000 Lb. Cast Iron Bulldog Hitch Standard
- Black โRock Guardโ Wheel Well Lining Standard
- Hide-Away Aluminum Storage Bumper with Black/Grey Water Drain Attachment Located Inside Standard
- Exterior Features
- 20 Lb. LP Tanks x2 Standard
- Fresh Water Fill Hook-Up Standard
- City Water Direct Hook Up Standard
- Fold Up Aluminum Double Entry Steps with Grip Tape Standard
- Custom Enclosed Slide-Out Battery Storage (Includes 2x 12 V Batteries) Standard
- Marine Grade Shore Power Connection with 25โฒ Cord Standard
- Outside 11Ov GFI Protected Outlet w/ Cover Standard
- Exterior LED Ground Lighting Standard
- LED Brake Lights Standard
- LED Marker Lights Standard
- High Mount Porch Lights x2 (1 on Each Side) Standard
- Custom Rear High Mount Oliver Sign Standard
- Convenient Exterior Entry Handgrip Standard
- Powered Pro Awning with LED Light Strip, Wind Sensor, Remote, & Upgraded Canvas Standard
- Outside Wash Station Standard
- Three Point Power Stabilizing System Standard
- Bonded Dual Pane Windows with Screen & Day/Night Shades x4 Standard
- Propane Easy Access Port Standard
- Interior Features
- Fiber-Granite Countertops, Tables, and Accents Standard
- Full Surround Over-Head Lighted Storage Compartments Standard
- Lighted Full Height Wardrobe Closet Standard
- EZ Winterizing System Standard
- MaxxFan Deluxe Remote Control RV Ventilator System Standard
- 2 Way Self Igniting Water Heater, DSI 6 Gal Standard
- Fresh Water Pump 55 PSI, 3.0 GPM Standard
- Dometic High Efficiency A/C (Approx. 11,000 BTU) Unit & Wall Mount Thermostat Standard
- LP Ducted Furnace Standard
- Monitoring System for Tanks and Batteries Standard
- White Day/Night Window Treatments (Excludes Bathroom) Standard
- Overhead LED Lights Standard
- LED Courtesy Floor Lights Standard
- Reading Light Package Standard
- Frosted Upper Cabinet Doors in Cabin and Bathroom Standard
- Water Accumulator Standard
- 120-Volt Receptacles Standard
- 12V/5V Dual Charging Stations Standard
- Kitchen Features
- Flush Mount Induction Stove Standard
- Refrigerator (12V) Standard
- High Rise Swivel Faucet Standard
- Custom Designed Storage Drawers with Dovetail Joints Standard
- Stainless Steel Microwave Standard
- Dinette, Seating, Sleeping and Storage Features
- Side Dinette (seats 2) Converts to Single Bed Standard
- Rear Dinette (seats 5) Converts to 74โณ x 52โณ size bed on Standard Floor Plan Standard
- Bathroom Features
- Molded Vanity with Toiletry Storage Standard
- Dometic 311 Toilet (Low Profile with Porcelain Bowl) Standard
- Exhaust Fan Standard
- Brushed Nickel Faucet with Pull Out Shower Wand Standard
- Sliding Frosted Privacy Window with Screen Standard
- Mirror Tinted Door Standard
- Waterproof Toilet Paper Compartment Standard
- Towel Bar and Hook Standard
- Central Heat Vent Standard
- Safety Features
- Fire Extinguisher Standard
- Smoke Detector with Alarm Standard
- Carbon Monoxide Detector with Alarm Standard
- LP Leak Detector with Alarm Standard
- Oversized Emergency Egress Window with Screen Standard
- Electric Features
- 120V Outlets on GFI Protected Circuit Standard
- Progressive Industries EMS Surge Protector Standard
- Converter with Built in Charge Wizard Standard
- Multiple Charging Stations, 12V DC marine-grade female socket & dual USB 5V adapters Standard
- External Plug & Play Port for Portable Solar Panels Standard
- Entertainment Features
- 24โ Flat Screen LCD TV (120V, requires Inverter) Standard
- Radio with FM and AM Dual Zone Audio Output, DVD, CD/MP/WMA/MP4, USB, Bluetooth and Remote Control Standard
- Custom Mounted Speakers x4 Standard
- Dual Exterior Coax for Portable Satellite/Cable Standard
Go Beyond Camp SitesExtend Your Stay & Enjoyment
Enhance your adventures with Oliver Legacy Elite small travel trailer upgrade packages, including popular Lithium battery and solar panel options for extended off-grid camping.
Take the Factory Tour
This is the best way to truly understand our manufacturing process and see what makes Oliver special.
Find Campers Near You
Seeing an Oliver trailer is easy, and we offer three convenient options.
