Oliver Travel Trailers
Lithium Batteries and Solar for Travel Trailers
Power of Oliver
Powering Your Travel Trailer: Oliver's Capabilities
Jim Oliver, founder of Oliver Travel Trailers, aimed to create comfortable trailers for traveling to beautiful, remote places. Equipped with modern features, Oliver models efficiently use power, enhancing the travel experience and embodying the brand's adventurous spirit.
travel trailer in cold weather
Empower Your Oliver
Designed for adventurers seeking comfort and self-sufficiency on the road, from battery management and solar energy options to efficient resource utilization. Whether you’re planning a weekend getaway or an extended journey, this introduction will help you unlock the full potential of your travel trailer, ensuring that every adventure is powered by confidence and convenience.
Powering Your Adventures
Lithium Batteries
Oliver Travel Trailers come standard with AGM Batteries, but we offer optional lithium packages if you want a more robust system. Oliver power packages include Lithionics Battery® with up to 640AH. These batteries are top-of-the-line with NeverDie® Battery Management System technology. Unlike many competitors, which offer lower-quality MOSFET-based BMS designs, Lithionics Battery® uses heavy-duty contactors for BMS on/off switching controlled by a custom microprocessor. Now, with Bluetooth® Telemetry to monitor battery voltage, state-of-charge, temperature, current, and status code remotely from your mobile device.
Lithium-Ion Iron Phosphate battery system with NeverDie® Battery Management System technology
Lithium battery systems provide weight savings, higher energy density, and less maintenance cost
Protection: Reserve, Pack Over and Under Voltage, Cell Over and Under Voltage, Cell Over and Under Temperature, Contactor Over-Temperature, Contactor State, Short Circuit, Over Current, Pre-charge
The NeverDie® Power Reserve: On-Battery + Remote Control Push-Button Access to 10% Extra Energy
World’s Highest Density and Smallest Size per Square / Cubic Inch
In-the-field BMS Firmware Upgrades- for-Life via the Bluetooth® APP
The industry’s Best Warranty: Tracked Daily and User Friendly
Bluetooth® APP Tracks State of Charge, State of Health, Battery Life and Diagnostics
Solar Panels
Oliver Travel Trailers offers optional solar panel systems up to 400 Watts that helps you use solar energy. These solar panels are built to work efficiently and provide a sustainable and eco-friendly power source for all your electrical needs. They can recharge your batteries during the day, providing a steady energy supply for lights, appliances, and other electronic devices. This helps you stay connected and comfortable even in remote locations.
Multi-Busbar M6 mono half-cell uplifted with PERC technology to guarantee higher output power and up to 22% maximum module efficiency.
High-performance cells encapsulated in EVA (ethylene-vinyl-acetate).
Rugged design to withstand high winds up to 2400Pa negative load, 1.375" diameter hailstones, and snow loads up to 5400Pa.
Standardized cell efficiency testing to identify and mitigate against damaged, color-deviating, or chipped cells to ensure optimal PV output.
Durable TPT back sheet - dissipates heat to insure better panel performance and lifespan.
Highly adaptable to temperatures below 0°F to 149°F with robust encapsulation and diffusion barriers that provide long term protection against PID damage.
Pre-installed bypass diodes inside junction box that minimize power drops caused by shading.
Newpowa Warranty: 10 years product warranty and 25 years power warranty.
Ducted Furnace and Enclosed Plumbing System to Keep Pipes Safe from Freezing
Inverter
Oliver Travel Trailers has an advanced inverter system of up to 3000 Watts in our optional power packages. The Xantrex Freedom XC Pro inverter converts DC power from the trailer’s batteries into AC power, allowing you to run appliances like microwaves, coffee makers, and televisions. By integrating this technology into the design enhances your convenience on the road and empowers you to embrace the freedom of camping without sacrificing modern amenities.
True sine wave 120 Vac inverter/charger with built-in transfer switch.
The Freedom XC inverter/charger offers premium performance in a lightweight compact package.
Easily upgrade firmware or quickly apply OEM-configured settings using the built-in USB port.
Monitor and configure your Freedom X inverter using the optional Bluetooth remote panel.
Shore Power
Oliver's outdoor package offers the convenience of shore power connectivity, enabling you to easily access electrical outlets at campgrounds, RV parks, or other locations where power is available. This feature allows you to plug into a standard 30-amp service. With shore power, you can efficiently run high-demand appliances such as air conditioning units, electric heaters, and multiple electronics without worrying about draining your batteries.
Propane
Oliver incorporates propane power as a standard feature for those seeking an efficient energy source while on the road. Propane systems are utilized for heating, hot water, and cooking, ensuring comfort and convenience even in remote locations. Propane's dual-fuel capability allows for efficient operation alongside electrical systems for flexibility in energy use. It enhances overall functionality, enabling you to cook delicious meals, take warm showers, and stay cozy on chilly nights. If you require more than our standard 20 lbs. tanks, we do offer 30 lbs. as an upgrade option on the Legacy Elite II.
Lithium Battery, Solar, and Inverter Power Videos
Lithionics Battery® BMS Technology
Newpowa Solar Power
Freedom XC PRO Inverter
