Oliver Travel Trailers
Oliver Legacy Elite II vs. Airstream Flying Cloud 23CB: Detailed RV Comparison
Side-by-side comparison of Oliver Legacy Elite II and Airstream Flying Cloud 23CB travel trailers parked in a scenic campground, showcasing fiberglass vs aluminum exteriors.
By: Oliver
Updated: January 12, 2026
When choosing between premium travel trailers like the Oliver Legacy Elite II and Airstream Flying Cloud 23CB, key factors include build quality, dimensions, weights, capacities, features, and pricing. This comparison highlights specs, pros, cons, and value for RV buyers seeking durable, towable options for couples or small families.
Overview
The Oliver Legacy Elite II is a fiberglass, double-hulled trailer built for four-season use, emphasizing durability and low maintenance. It offers standard or twin bed floor plans, sleeping up to 3.
The Airstream Flying Cloud 23CB features iconic aluminum construction with a corner bed layout, sleeping up to 4 (or 7 with bunk option in 23CBB variant). It’s known for spacious interiors and classic design.
Design and Construction
Oliver: Insulated double-hulled fiberglass shell prevents freezing; aircraft-grade aluminum frame; Dexter suspension with quad shocks. Pet-friendly, easy-clean surfaces.
Airstream: Semi-monocoque aluminum superstructure; thermal barrier; tempered tinted windows. Fluorocarbon-treated exterior for UV protection.
Oliver excels in structural integrity and insulation; Airstream in open feel with larger windows.
Dimensions and Weights
FeatureOliver Legacy Elite IIAirstream Flying Cloud 23CB
Exterior Length23′ 6″23′
Exterior Width7′8′
Exterior Height w/ A/C9′ 8″9′ 9″
Interior Height6′ 6″6′ 7.5″
Interior Width6′ 7″7′ 7″
Dry Weight4,900 lbs4,761 lbs
GVWR7,000 lbs6,000 lbs
Hitch Weight490 lbs654 lbs
Cargo Capacity~2,100 lbs1,239 lbs
Oliver narrower → easier towing, better fuel efficiency.
Airstream wider → more interior space, harder to tow, lower fuel efficiency.
Capacities
FeatureOliverAirstream
Fresh Water32 gal39 gal
Gray Water32 gal21 gal
Black Water15 gal18 gal
LP Tanks2 x 20 lb2 x 30 lb
Oliver has larger gray tank; Airstream slightly more fresh water.
Interior Features
Versatile premium floorplan with twin beds.
Interior Twin Bed Floorplan
Oliver: Fiber-granite counters, induction stove, 12V fridge, Dometic A/C (11,000 BTU), LP furnace, MaxxFan vent, LED lighting, full bathroom with porcelain toilet. Convertible dinettes.
Airstream: 2-way 5 cu ft fridge, 25,000 BTU furnace, 13,500 BTU A/C, convection microwave option, panoramic windows, convertible seating. Spacious with optional bunk.
Exterior Features
Oliver: Powered awning, dual entry steps, exterior wash station, solar port, LED lights, stabilizing jacks.
Airstream: ZipDee awning, stainless steel guards, torsion axle, exterior shower, solar pre-wire option.
Pricing
Oliver: Starts at $79,995 (2026 model).
Airstream: Starts at $103,900 (2026 model).
Oliver offers better value with more standard features.
Pros and Cons
Oliver Pros: Superior build quality, four-season ready, lower price, higher GVWR.
Cons: Narrower interior, smaller tanks in some areas.
Airstream Pros: Iconic design, more interior space, larger windows.
Cons: Higher cost, potential for dents in aluminum.
Conclusion
Choose Oliver Legacy Elite II for durability and affordability in off-road or cold-weather camping. Both are top-tier RVs; test tow and tour to decide.
Privacy Overview
