Apparently, Oliver has now switched to the Chinese Tires. This has been confirmed by a reliable source.š
It's possible a dealer swapped the tires out. I've heard of dealers doing that sort of thing. Example: The sale of some other brand trailer they have on the lot is held up because the customer doesn't want the Castle Rock tires. There's the unsold Oliver over there with brand new Goodyears in the same size. Problem solved!
Winter heating with a small electric heater
Galileo replied to Carl Hansen's topic in General Discussion
Sounds like a good idea. I typically like to keep my vehicles as āstockā as possible as Iāve found a lot of aftermarket accessories to be pretty poorly made and (IMHO) detract from the value of something rather than enhance it. Iām generally a firm believer in the people who designed, built, and service a specific item being more expert on that item than I am. I also realize that Iām unlikely to live forever and be the only owner of a vehicle, so I like to have it as OEM as possible to retain resale value. That said - when I see obvious poor design, construction, or installation - like HUGE air infiltration issues, or duct routing on a furnace that chokes off airflow or has such long runs that no air flow can be felt at a vent when the blower is running - THEN Iāll carefully consider and select ways to improve upon something that was poorly done from the factory. - Today
Point well-taken on the replacing the socket and/or plug - and if this one were old or worn Iād agree. However, since this one hasnāt been subjected to multiple plugging/unplugging cycles - which would cause one to be loose or weak - I doubt replacing it would yield any better results. Short of cutting off the plug and hard-wiring it to the source, replacing it would be unlikely to solve the problem or eliminate the need to check on it periodically. Additionally, though the receptacle the fridge plugs into IS a standard duplex outlet, the one the battery charger plugs into is a special one that that snaps into the back of the A/C breaker box, and probably doesnāt have a higher-quality replacement available. Only cutting off the plug and hard wiring it will truly āfixā the issue. Anything less is just a band aid. IMHO - having installed items like the battery charger and fridge plug into a household socket is a pretty cheesy way to handle power on a vehicle subject to vibration and shock as part of its everyday mission. Kind of akin to using household Romex on a boat. (Which Iāve seen done - but not by professionals or knowledgeable laymen.) And correct on the āautoā mode on the Norcold fridge switching to A/C when available. It normally does this. When it stayed in LP mode even with shore power connected is when I went into trouble-shooting mode. The issue was not my failure to understand or select the operating mode I desired.
Brand new trailer picked up last week, but don't know it was a Dealer or Hoenwald.
marsharini started following SeeLevel Tank Monitor Issue
Thanks everyone for the suggestions. Will check further report back.
Steve Morris replied to Carl Hansen's topic in General Discussion
Iād like to hear more about what kind (brand, model) was installed From Hankās FB post: āCamping Northern Florida. 31F this morning and a very comfortable 76F inside. A small space heater on the low setting only. 12VDC warming blankets on the beds. Using only 11 amps shore power. Basement temperature is holding at 66F. Two small 12VDC fans, one port and one stbd side keep a gentle air flow circulating thru the basement. With the bathroom vanity port open, cabin air is flowing into the basement and returning thru the return grill below the bed. The basement partitions have been removed and a 700W Xtreme heater is mounted inside (auto on at 43F off at 55F) for very cold conditions. Last week camping at 14F the Xtreme heater did come on to maintain a temperature well above freezing in the basement while we were gone.ā If you are a member of the Oliver Owners of America facebook group, look up member Hank White, and scroll through his group posts. This one was from January 2025, with several photo. Hank has done a *lot* of cool modifications, and having seen them in person, Iāve added several to my list to things to do. -
Hmmm.....I wonder if his trailer was bought from a dealer or he possibly bought it from a private owner.
Brand new owner discovered Chinese made tires on his new trailer. Castle Rock Tires. Oliver has stated they are installing Goodyear Endurance 15", 10-ply "E" Rated tires. So how does a Chinese tire end up on a brand new Oliver trailer? Chinese tires have resulted in hundreds of blowouts on stock built trailers where everything is cheap. This is strange. I told him he needed to reach out to Oliver asap.
I'd say, this is not such a good idea. Go back to your post from last year and review Geoff's suggestion @Snackchaser. Time to fix the issue vs. adding a checklist item. Not sure re the Norcold fridge controls, but on our Dometic when in LP mode it will stay there by design. When you select "Auto" it will switch to AC if available, or DC when not plugged in.
RM 2454 Problem Heading into SE Colorado Boondocking
jd1923 replied to Geronimo John's topic in Mechanical & Technical Tips
Good work Bill, and you made GJ's day! I have this as part of our "2016 Elite II Owners Manual" PDF, but every time a fellow forum member posts an electronic PDF file, a manual or schematic, that relates to our hull, I download it and save electronic copy. I prefer using PDF files. Not just for the absence of carrying the big basket of paper, but for ease and speed of search. When GJ wrote his model # in the title of this post, I search my 557-page PDF copy of the Oliver manual for keyword "2454" and in 2 seconds it jumped to page 151 where the Dometic fridge manual starts in this long file. I use the Ctrl-F hotkeys, type a keyword, and there it is. No time taken to review the Table of Contents, search an index in the back pages or thumb through paper. This search capability and other tools we have today are so useful! I show my Project Management Professional (PMP) students this, in every class I teach, as they must navigate through multiple PMI standards, 1000s of pages of content they could see on their PMP Exam. I use the Ctrl-F search function several times a day for anything I'm looking for, searching the content of web pages, doing Oliver research and searching the shop manuals for the many cars, trucks, bikes and appliances we own. It's so handy! š You sure have your files well-organized though, and most people still prefer paper copy. The young professionals in my classes are strongly against printing long files for sustainability concerns, like the 290-page slide deck we use, at 2 slides per page, OMG it's a lot! 𤣠-
Galileo started following Cleaning the gap around the linoleum floor and Accessories unplug themselvesā¦
In just a routine look under the aft dinette seat, I discovered the battery charger plug to be halfway unplugged yet again. Two thoughts: 1. Add checking this to a periodic maintenance checklist. 2. Itās about time for my fridge to stop working in A/Cā¦
I guess we could do that - we have a set of ten of those levelers and I use my LevelMate Pro + to maneuver into site where I rarely need more than two of them. Just sounds like a bit of a pain. Then again, Iāve been known to chock the wheels and unhitch to raise the nose of the trailer at some dump stations.
That beats stepping on them in bare feet in the middle of the night! š
@Geronimo John and of course, you have the tank diverter valve pointing at the full tank. When these crossover valves switch from the empty side to the full side its secondary pressure is lower. -
We also drive our truck onto Legos when we hit a dump station.
Townesw replied to Geronimo John's topic in Mechanical & Technical Tips
@Geronimo JohnI hope that has the answers that you are looking for. When I brought hull 313 home in March 2018 I crawled all over it taking pictures of data plates on equipment with model numbers and serial numbers. I then went online and found manuals (ownerās, installation, service, parts, whatever I could find) for the model and serial numbers that were on our Oliver. Some of the manuals on the Oliver site arenāt the correct manual for the model and serial number range of the equipment used in our Oliver. I then printed out the manuals and put them in 3-ring binders that I carry in a tote that fits under the front dinette seat. I know itās bulky and isnāt as convenient as a link on a phone but I can open a manual and look at it and make notes while Iām working on something. Bill -
@Geronimo Johnsee if you can find any answers in this service manual https://fourwheelcampers.com/NewDometicRefrigeratorManual.pdf I had trouble getting my RM2454 to cool in Ashland VA last week after working fine for 3 weeks. It was just too hot there at 97F for the absorption cycle to work well. I temporarily added a double bladed window fan from Lowes. Still wouldnāt work even at night. Turns out that too much air movement is as bad as not enough. I turned the temporary fan off and the refrigerator started working again. Bill -
I have a manual for model 709 and 709-PH. The battery level displayed is determined by the voltage supplying the SeeLevel panel. As others have said see if itās getting power. You said the tech plugged a new panel in and it was dead also. I canāt believe that the tech didnāt also check the fuses as that would have taken a few minutes. I would check the voltage going into the panel and work back from there This schematic is for 2018 LEII hull 313 so it might not be the same for your hull Bill
JD: Correct on both. Still in Denver and it always works perfectly for months up at King Mountain where we basecamp at 5,300. I think that well over that elevation we would need the other smaller orifice to reduce gas flow due to lack of O2 higher up. Not the case with ours in Denver now. Currently, we don't get anywhere near the gas flow to even heat the ammonia hot enough to flash to cool. Hopefully one of the owners can respond with info about the gas valve voltage and possible test procedure for it. It's a long shot, but worth a try. I have heard others have had mother board issues, but never heard of the refer gas valve going south. Along the gas thread: I'm also wondering if there is a screen that keeps trash from tank insides or junk from bad propane that could clog or plug the oriface? If so, where would it be located? GJ
Spray cleaner of your choice (Fantastik, 409, etc) and an old toothbrush - then a few paper towels. We keep a āDustbusterā in the trailer for routine cleanups. Keeps the grit buildup to a minimum. A long-term fix -might- be to fill that awkward gap with some kind of caulk. That way thereād be no gap to collect crud. Iād be very careful with acetone or any petroleum or solvent based liquids. I think youād risk eating away at the flooring adhesive or even the flooring itself. -
I believe we have the same model Dometic fridge. Ours has worked fine several times camping in CO outside of Telluride and on the White Mountains in AZ, both above 9K ft. Also, it reads like GJ is still in Denver just over 5K ft. GJ, you're getting the 3 clicks, so all electrical controls are fine. You certainly have a gas issue. I have no experience there but believe your "analysis and investigate" lists are right on. Best wishes, JD -
Iād like to hear more about what kind (brand, model) was installed - as our floor is typically ice-cold. Though I assume itās due to the cold air infiltration, it could be just from the frigid air blowing in from the furnace ducts and return grille. A radiant floor heat would be a first-class upgrade to the Ollie.
